PhatStats PC Performance TFT Display
Arduino TFT PC Performance Monitor with Client software
PhatStats ili9341 TFT PC Performance Monitor Display
PhatStats (TFT) form an Arduino serial display. HardwareSerialMonitor is a PC serial client, both are written by Rupert Hirst and Colin Conway.
HardwareSerialMonitor Windows client reads the hardware statistics from the PC.
This data is forwarded over the hosts’ serial  port to an Arduino compatible micro processor. It is then, displayed using the Phat-Stats sketch.
This project, assumes you have a above average experience with Arduino, the IDE and the compatible boards available.
The HardwareSerialMonitor was designed for dedicated GPU's . Your mileage may vary with Integrated Graphics
To help with construction there are hook up guides, links below:
Phat-Stats ILI9341 TFT Display Hook up Guide
Going Forward:
The project needs to be ported over to LibreHardwareMonitor , a fork of OpenHardwareMonitor  for future support, as this gets a lot more updates for new PC hardware. If anyone can help please get in touch, thanks.
http://tallmanlabs.com
http://runawaybrainz.blogspot.com/
https://github.com/koogar/HardwareSerialMonitor
https://github.com/koogar/Gnat-Stats
Gnat-Stats (OLED) has moved to a new project page here
The above software/code is licensed under the following terms:
GPL v3
Gnat-Stats, Phat-Stats & Hardware Serial Monitor Copyright (C) 2016 Colin Conway, Rupert Hirst and contributors
This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with this program; If not, see http://www.gnu.org/licenses/.
HardwareSerialMonitor only was inspired by Psyrax's "SerialSender". Psyrax is given attribution and thanks, by being an honorary member of the project.
WeeStatServer-0.5.2_Libre.0.9.3-pre256_Binary.zip
Alternative to HardwareSerialMonitor but uses LibreHardwareMonitor libraries. Requires .net6
x-zip-compressed - 3.96 MB - 10/06/2023 at 15:16
Download
HardwareSerialMonitor_v1.4.4_9600_OHM.0.9.6.1.PR_NET4.8_Binary.zip
added experimental Intel Jasper Lake Support added experimental Intel Rocket Lake Support added experimental Intel AlderLake support added Alde Lake Mobile support added Intel RaptorLake support Boris Vogel https://github.com/BrsVgl/openhardwaremonitor
x-zip-compressed - 1.46 MB - 09/22/2023 at 11:57
Download
x-zip-compressed - 171.34 kB - 06/20/2023 at 00:27
Download
x-zip-compressed - 272.40 kB - 06/20/2023 at 00:24
Download
TachoStats_V3.1.7.1_SeeedRoundDisplay.zip
https://www.seeedstudio.com/Seeed-Studio-Round-Display-for-XIAO-p-5638.html Seeed Studio Round Display for XIAO - 1.28-inch round touch screen, 240×240 resolution
x-zip-compressed - 180.38 kB - 06/20/2023 at 00:07
Download
View all 11 files
View all 8 project logs
View all instructions
alexyecla wrote 02/19/2019 at 11:08 point
Hi Rupert, thanks for your proyect i'd love it, I'm trying use your gnat-serial-monitor, and detects usage. and temps, but I want send more data like vram, voltage, cpu & gpu freq...so how I can add these parameters?? hope you can help me.
Belean wrote 01/12/2019 at 09:14 point
Hi Rupert! I've been looking for a project like yours for a long time. So thanks a lot! But I'm stuck with one meter to go, can you help me out? Everything works great, but the data is missing: no temp, no hardware names, just CPU...blank, GPU...blank, hertz...blank. I've an i7-7700 and a GTX 1080. Hardware Serial Monitor tray v1.1 is up and running. Any suggestions could be very useful to me, thank you!
Rupert Hirst wrote 01/13/2019 at 20:53 point
HI Belean,
Did you run HardwareSerialMonitor as Admin?
Belean wrote 01/13/2019 at 21:35 point
Thaks for your answer Rupert! Yes I did. HardwareSerialMonitor_v1.1. And OpenHardwareMonitor v0.8.0-beta works fine, if this can help. You can confirm that if I did everything right it should work even on an updated PC, right? There should be no external variables that could interfere with the project therefore?
Rupert Hirst wrote 01/13/2019 at 22:50 point
if you ran the app as admin and you have selected the correct com port from the tray it should work. The only other things that may effect it are folder permissions, the arduino Com port driver, Antivirus or a firewall blocking the com port.
Nosdrahcir Iniburehc wrote 01/09/2019 at 21:52 point
Hello. Excellent project. I'm trying to reproduce this project, but I'm having the following problem. Can you give me a hand?
https://imgur.com/a/frKznmH
acid company wrote 12/11/2018 at 18:17 point
how to fix form1 windows problem on serialmonitor?
acid company wrote 11/24/2018 at 13:26 point
great project. thanks for share it but i want to same build for my pc. how i set up this parts and how i install to code in arduino? can u help me about this issue?
valentin-bykov-1990 wrote 11/13/2018 at 08:43 point
tell me please,what command do I need to write to display information about the gpu ram load?
Rupert Hirst wrote 10/21/2018 at 21:24 point
Asrul...  Which display have you got ?
Asrul Yol wrote 10/19/2018 at 22:45 point
hey Rupert, im really new to adruino. im trying to varify the scetch, and i got "splashscreen was not include in this scope" error. How do i fix this?
Rupert Hirst wrote 10/20/2018 at 00:03 point
Hi,
Did you alter something in the sketch before you verified it?
Did you download the libraries?
In arduino IDE 1.85 with correct libraries it should complie just fine.
Just because it complains about "splashscreens" does not mean the problem is with that. It could be something as simple as you deleted or  missed out a semicolon somewhere above, in the code.
Asrul Yol wrote 10/20/2018 at 12:11 point
hi.. i've find out the problem and able to upload the sketch.. but now no display.. can u help me on this.. i ve try as your previous comment below.. but still didnt light up.. any suggestion?
valentin wrote 10/19/2018 at 13:47 point
really very happy with this monitor. I will buy WS2812 digital leds right now ;)
PhuocBull wrote 10/16/2018 at 08:16 point
OMG ! This is so great !
valentin-bykov-1990 wrote 10/15/2018 at 12:48 point
led is circuit module RGB?
Rupert Hirst wrote 10/16/2018 at 09:41 point
Its a NeoPixel ring with a custom cut overlay.  i would have posted more pics but hackadayio has a limit of 6 pictures.
valentin-bykov-1990 wrote 10/16/2018 at 11:03 point
and on what contacts deduced? amazing thing happened))
Rupert Hirst wrote 10/16/2018 at 10:22 point
Glad to see Gnatstats/HardwareSerialMonitor detects your 8700k Coffee Lake
https://www.youtube.com/watch?v=8u8uStfVLHc
Rupert Hirst wrote 10/16/2018 at 11:36 point
I saw your CPU on the OLED display on Thingiverse ;)
If you are the same person as below
valentin wrote 09/18/2018 at 20:41
I realized a shell in 3D printing from this project:
https://www.thingiverse.com/thing:3107543 "
But maybe i am wrong
valentin-bykov-1990 wrote 10/16/2018 at 11:38 point
this is not me)
valentin wrote 10/19/2018 at 13:18 point
it's me ;)
kot0005 wrote 10/12/2018 at 23:31 point
Hi, Thanks for this Project. I am newbie using Arduino, So which one of the libraries do I use ?  I used all of them and when I upload it works but my oled screen doesnt light up. I made sure the pins outs are right.
Rupert Hirst wrote 10/16/2018 at 09:46 point
You have to use all of the libraries mentioned.
You have to uncomment  one of the lines for the perticular OLED display you are using...
//#define OLED_SSD1306
#define OLED_SH1106
or
//#define OLED_SH1106
If your using a display with a ProMicro on the back as per the pictures
you will need to uncomment
 //#define enablepowerPins
And uncomment the one below it in the sketch for you perticular screens power requirements.
check you have the correct polarity for the selected OLED screen!!!
Also make sure you i2c address correct in the sketch
valentin-bykov-1990 wrote 10/12/2018 at 03:46 point
for itself decided to use this holder(his own and can convert it) https://ru.aliexpress.com/item/128X64-0-96-O/32871594368.html?spm=a2g0s.9042311.0.0.7a2833edrKLWbw
valentin-bykov-1990 wrote 10/09/2018 at 14:29 point
Hello, very cool project, I would like to ask the question, is it Possible to add a second physical display with the output of information about the state of RAM and paging file?
Rupert Hirst wrote 10/09/2018 at 18:06 point
Yes it is possible but not with the present library. U8GLIB supports multiple screens, It would mean a extensive rewrite of the code.  I am not sure if open hardware monitor supports displaying the page file.
valentin-bykov-1990 wrote 10/09/2018 at 18:38 point
it's sad, because I was ready to order two displays ((by the way there is an idea about the front panel for the case, if you make it out of black Plexiglas,the display will Shine through and off will also be nice. and please sorry, i use google translate))
Rupert Hirst wrote 10/11/2018 at 12:28 point
I  am working on a enclosure for a variant of GnatStats at the moment :)
Rupert Hirst wrote 10/08/2018 at 23:44 point
GnatStats Release v1.3
Version 1.3:
Option to trigger an event at a given CPU or GPU threshold eg: LED indicator at 100% CPU Load.
Top Config option to disable all pre-selected power/gnd pins on Arduino pins D4 and D5 when not powering OLED from ProMicro
Top Config option to disable/enable "activitychecker" (Enable blank screen on serial timeout eg: PC powered down, Disable to retain last sampled info eg: PC crash or overclocking diagnostics)
NeoPixel Ring CPU/GPU Bargraph example
Rupert Hirst wrote 09/18/2018 at 21:06 point
Thats really great Valentin. I will be sure to link it in the next update :)
valentin wrote 09/18/2018 at 20:41 point
valentin wrote 09/07/2018 at 19:13 point
Hello, I started in the Arduino the screen works very well but I wanted to make sure that to change screen (D1 D2 and D3) you have to press a button. I have no resistance, so I want to put the button in INPUT_PULLUP. But I have a lot of difficulty. Can someone help me and send me the file?
B-Gits wrote 04/27/2018 at 00:40 point
Hi Rupert,
whats the pw for the ryzen zip file? I do have a ryzen and i am not able to get my temps displayed on my oled thingy.
Regards!
Diegomud wrote 04/12/2018 at 17:41 point
The project is excellent, but I have a problem, I have a screen nextion 2.4 '' 320x240, will it be possible to implement it without changing the code?
Rupert Hirst wrote 10/09/2018 at 18:07 point
Nope
