Run on Startup Win10
A project log for PhatStats PC Performance TFT Display
Arduino TFT PC Performance Monitor with Client software
rupert-hirstRupert Hirst 06/15/2020 at 22:210 Comments
Due to the Windows 10 not allowing programs to run on startup as admin, here is a workaround script.
1)  Right-click on the HardwareSerialMonitor.exe , go to properties, then compatibility and check "Run as Administrator"
2)  Create the VBScript using a text editor (I used Notepad)
  Set WshShell = CreateObject("WScript.Shell" )
  WshShell.Run chr(34) & "C:\Program Files (x86)\HardwareSerialMonitor\HardwareSerialMonitor.exe" & Chr(34), 0
  Set WshShell = Nothing
(The above path is an example, edit this to where your HardwareSerialMonitor.exe path is located)
Save the script as "HardwareSerialMonitor.vbs" (no quotes)
Note: Make sure to save it as a .vbs not .txt
3)  Now place the HardwareSerialMonitor.vbs in the HardwareSerialMonitor folder:
4)  Goto the Windows startup folder
%AppData%\Microsoft\Windows\Start Menu\Programs\Startup, alternatively access it by Win+R ⇒ shell:startup ⇒ Enter
Create a shortcut to the .vbs script above by right clicking then "New" ⇒ "Shortcut" ⇒ "Browse" for the "HardwareSerialMonitor.vbs" Script and select it.
HardwareSerialMonitor Should now run on startup
