Prototypes are out for Testing!
03/15/2024 at 19:22 • 0 commentsRight, so there are 4 prototypes in the wild! The first one will stay at Crowd Supply for pictures etc, so actually not so much for testing, but more as a reference and display. The second one just arrived today at my most loyal supporter Chad. Hope you enjoy putting your kit together! Of course, I am very curious to get some feedback from you :) The third PolyKybd is currently in Germany. I handed it over to 0x17, who organized CCH Con this year in Reutlingen. Hopefully, he can pass it on to some other testers soon. All these boards are hardware revision 2.2.
The last one is a ...ahm... a "Frankenboard" with one side having revision 2.2 and the other side is a revision 3.1 board. It stays with my good old friend cbirklbauer as my most and highly trusted software engineer of choice.
I hope your comments and observations will improve the software quality which is still a bit rough, but we will get there :)
So what is different with revision 3.1? Not that much! I exchanged the RGB LEDs as the WS2812B-Mini-V3 a lot of times had manufacturing issues. With the new XL-3030RGBC-WS2812B, I haven't had any issues and they appear to be a bit brighter. Another component, I exchanged, is the socket for the 14pin ribbon cable of the displays as the original part has a production delay of about half a year.
The only real functional change is a fix for the USB-Sense. With that, the keyboard can tell, which side is connected to the host (and then handle the logic and communication). In revision 2.2 the software does that by detecting a USB connection. That works in most cases, but maybe not for some older BIOSes or in case you power up the keyboard via an active USB-Hub without a PC connected to it. This should be fixed in 3.1 as I can assume that the side with the power, will be the host side.
Just a few days ago, I assembled the first two PolyKybds with both sides on revision 3.1:
A low-profile version with Tecsee Medium switches.
And here is an experiment where only R1 has low-profile switches. Let's see how comfy that is...
Other than that, I had to do some number-crunching to make sure, that the Crowd Supply campaign will be financially sound. There is nothing I can show you, but these tasks also have to be addressed. The only productive side-task I had, was the construction of the legs:
Looks like a fit:
If these legs are not enough, I encourage you to come up with a custom tenting solution.
For that, there are a couple of holes on the back and some pre-perforated holes on the side, which you could drill or break out. Either glue in some threaded inserts or just a 3D-printed stand/leg of your choice!
Best, Thomas
OLED burn in?
01/28/2024 at 16:03 • 0 commentsOf course, we all heard about that, there are plenty of articles and videos out there.
Maybe the more important question is: Will this be a problem for the PolyKybd?
To find out let's take a look at my current Prototype, which I now use for 3/4 of a year - I even bring it to the office, so it is used all day long at least 5 days a week.
Before looking at the first picture let me mention that you will see some lines flickering (some lines appear lighter on the pics) here and there because of the refresh rate of the display not being synced with the camera sensor.
Here, we see the left side when not pressing any key:
Let's focus on the 'd':
And now let's compare to the upper case 'D':
Notice any difference in the brightness apart from the flickering lines? No? How about here:
Same key, also here:
As you can see, you won't recognize little brightness differences on specific pixels of the glyph.
But where is the burn in effect now? Alright, of course, I can forcefully make it visible. For instance, if I invert the whole screen, like that and adjust the brightness and contrast of my camera:
Now you can see the lowercase 'd' which is displayed most of the time (+ some flickering at the bottom).
So there it is! Yes...
Will it affect your daily work? See the next pictures taken from 15cm (~6 inches) away from the keys (so multiple times closer than your eyes - at least I hope that's the case):
So at this point, I would say: Maybe not.
This is great news. Additionally, let me post similar pictures in a while again to get some more empirical data!
Nevertheless, I'm doing my best to protect the screens:
1) After a minute of inactivity I switch to the idle mode, or as other people call it: "The screen saver mode": In that mode, the displays turn on and off randomly with very low contrast and usually just a few of them at a time. It should give you enough clues to find the right key while avoiding permanently turning on all displays.
2) After another 5 min (or whatever you set) all displays turn off and wait for the next key stroke. You can configure whether that first key stroke should be accepted and forwarded to the PC.
I tried one more measure: To randomly offset the displayed characters by 1 or 2 pixels in x and y. However, that didn't look satisfactory as you can notice little offsets very well.
What do you think? What's your impression? Have you ever had to deal with OLED burn in?
Testing another 3D printing farm and preparing a first kit
01/28/2024 at 16:01 • 0 commentsFrom the beginning, I have been using 3D prints for the PolyKybd cases and other small parts and was always satisfied with the quality of these resin prints. As there are already plenty of options, I wanted to see if there is a 3D printing farm in Europe comparable in price and quality to my go-to-shop JLCPCB:
In the picture above, you can see that all the small parts from JLCPCB have a good surface finish, there are hardly any marks from support structures, and the dimensional stability is impressive. Especially the last point is important so that the MX stem firmly fits.
So I went off to https://craftcloud3d.com (where you can get offers from various 3D printing farms all over the world) and indeed found a company that would offer similar prices for 3D prints with higher order quantities in Europe. Even if the prices are slightly higher, there would be no import toll within Europe in contrast to anything imported from China. With that in mind, I ordered a smaller batch (which is unfortunately quite expensive compared to high-quantity orders) to see how that works out...
While the support was quite responsive with questions before starting the 3D prints, it took longer to ship the prints from Sweden to Austria than from China to Austria :'(
However, I'm patient, and waiting a week longer is not a big deal. When the parcel finally arrived, I opened it and was quite disappointed: Straight corners were bent and twisted, the surface showed a lot of spots from the support structure, there were seems and when measuring with the calipers it was clear that the prints were unusable:
Even more visible on the cases:
Comparing to:
Of course, the cases are different iterations, but I believe you can still spot the quality difference.
I reached out to the print farm and they told me that they had an issue with their resin that was discovered later, so I gave it one more try and they sent me a batch of replacement parts free of charge:
While the dimensional stability improved, there were very ugly break-outs where the support structure was attached:
Also, the surface finish is still far away from JLC, which is very visible in direct comparison:
It might be worth trying one or two other farms, but that first experience was not the best.
In the end, I got my 3D prints from China once again and put my first test kit for crowd-supply together:
At some point, I should think about the packaging. For now, I just put everything together with bags, trays, and wrapping I had at hand.
I hope you get a good rest during this holiday season and wish you all the best in 2024!
PolyKybd Split72 Kit will launch on CrowdSupply!
10/06/2023 at 16:58 • 0 commentsYes, right! Look at that screenshot! The PolyKybd is at the top right!
As of today, there is a pre-launch page live at CrowdSupply, where you can register to get all updates on the campaign for the kit: https://www.crowdsupply.com/polykybd/polykybd
Of course, there is still much to prepare before the actual launch of the campaign and I would like to come up with some (long time ago requested) typing videos. Nevertheless, this is the first step in making this whole project a reality - not only for me but for you folks out there as well.
Why Crowd Supply?
There are plenty of crowdfunding platforms out there and every one of these has a different target audience. Crowd Supply is maybe the most hardware-centric platform, where backers have a good technical understanding. And this is exactly what I'm looking for: Folks who are not scared of flashing the firmware, folks who can use a screwdriver! I want everyone who buys a kit to be happy with it, even if you have to tinker a bit to make it fit to your needs - be it the software or the hardware by adding a rotary encoder. After all, we are individuals, right?
Instructions are Ready!
09/09/2023 at 20:13 • 0 commentsYes, finally I got the build guide ready on my HW github repo: https://github.com/thpoll83/PolyKybd
I wanted to wait for my first batch of pre-production displays to be showcased in the instructions (along with the regular soldered ones, you have the choice) so there was some delay. The first batch:
Around 500 displays, all with long enough FPCs to directly connect to the socket! No more FPC-toFPC soldering needed :)
With that, the build guide is finally out! It contains a lot of pictures and was more work than expected. If you are impatient and you do have a hot-air rework solder station, you can go ahead and start putting a PolyKybd Split72 together :)
If you don't feel confident enough for the FPC soldering part or you don't like to buy all the different parts across various sources from the internet... Stay tuned! As you may know from previous post I'm trying to put a kit for PolyKybd Split72 kit together, just don't expect it next month or this year for Christmas.
And I can also tell you that the new displays are much smother in operation compare to the old ones, where I extended the flex cable!
What else happened?
Besides a little summer vacation (yes I need a break from time to time too) a VERY similar project came up: https://www.kickstarter.com/projects/daptkey/daptkey-redefine-your-life-with-a-customizable-keyboard/description
They "had" the idea withe the OLED displays in October 2022🤔
Not sure what to think about it. They use James Brown's mechanical solution of a separate slot in front of the key switch and the flex cable comes out at the bottom edge of the key cap. I do wonder if there is any mechanism implemented to reduce the OLED burn-in? From the video, I would rather say no. Granted, the look of the case and caps have a nice finish and these guys moved quite fast from development to production.
What are your thoughts? Let me know in the comments below!
Customized Displays Arrived!
07/14/2023 at 10:58 • 3 commentsHere they are! It maybe doesn't look like much, but this is really a big step forward: The first 2 prototypes of the displays with the extend length FPC straight from the factory.
Maybe not such big news for all Ko‑fi supports, as I already announced the work on this in a private post some time earlier. Still, I'm happy, that I was able to get these 2 prototypes and soon a few hundred pre-production samples without ordering 10.000 pieces right away!
So, here you can see the first one fitted into my prototype with all the other displays:
By intention these are just a bit shorter than the manually extended ones to reduce the needed space below the PCB, since there is even more space requirement when pressed. And I'd like to avoid the cable touching the case as it adds extra resistance when pressing:
There is still some wear from the rough edges of the FR-4 slot and I've been toying around with plastic inserts to give it some more protection.
However, that didn't lead to a good solution yet and it might the easiest to just a apply a bit of thick paint/coating around that edge.
From the outside the new displays look almost identical:
(first row in the middle)
From the first picture you might have noticed that there is no hatched copper fill on the backside of the FPC. With the absence of that, the flex cable got much smoother and the typing experience in my opinion improved a lot now :)
Keycap Orientation
Apart from these great news, I have been experimenting with the orientation of the keycaps:
I find it a bit difficult to always find the right row, if all keys are uniformly flat. There is a little notch for the index fingers, but still I do hit the wrong key from time to time. This could be a matter of taste, but I also hope to improve the ergonomics with this little tweak. In the end everybody can choose the right profile according to personal preference. Here a photo from the second prototype I'm putting together:
The next possibility that comes to mind would be a slight step between each row like most commercial keyboards have:
In that case you might need some tenting. Or you just come up with you own version. The stems are made in OpenSCAD:
https://github.com/thpoll83/PolyKybd/blob/master/keycaps/keycap_stem.scad
It should be rather easy to customize. The only limiting factor is the length of the flex cable.
Repository Cleanup In Progress
Yes, the long promised cleanup of the repository is in progress an I'm writing a short build guide. More on that next time..!
Thanks, Thomas
Finally, After 2,5 Years!
05/24/2023 at 05:06 • 0 commentsIt is finally working! Both sides can be used without modifications! 😁
But that is only for the hardware of course, software is never done as we all know!
Current Software Work
The code is already much cleaner and my current schedule is about testing through the optional devices like rotary encoder, pimoroni trackball and cirque trackpad:
- The rotary encoder works.
- The pimoroni trackball needs a QMK update as it has some issues in my version (the cursor becomes very shaky). To be done soon...
- The 23mm cirque trackpad works after resoling some configuration issues. It is a bit small, so I might try the next size as well.
Open Software Issues
- The status display on the right side (slave) turns on unexpectedly after the turn-off timeout (just resolved minutes ago, so this is also done)
- An issue I had in the past: RGB LED matrix flickers on the master side. Maybe because I changed the LAYOUT macro to reflect the key orientation..? Need to check if I have to do the same for the led_config.
- Easy way to configure the layout. Right now I still have to flash the firmware every time, but at some point I would like to switch to something like Vial so that can be done without flashing anything.
- Some more Icons for all the special function keys.
So you see, there is still plenty of work left.
Further Software Improvements Ahead
- This is out of scope for now but definitely the goal: To have a program on the host side to switch the OS input language and also send program context information to the keyboard so that customized symbols can be displayed.
- To avoid burning out the OLED displays, I plan to shift the displayed content slightly once a while. This is nothing fully developed yet, more an idea.
Final Touches
The PCB is in a production ready state, however I would like to apply a cosmetic change to the silkscreen (some pin markings are on the wrong side - luckily only on the silk screen).
And this is more about the general mechanical design:
If possible, I would like to have some plastic inserts for the flex cable slots:
With that, the edges would be soother and make the flex cables maybe life longer. I had no such issue so far and the edges are not rough, but if it is possible, I'd like to try. It sounds like an improvement to me. I was also thinking about plated slots, but these have size limitations which makes it impossible (at least at JLCPCB).
Layout
Of course everyone can come up with an own layout, but let me quickly show off my current choice (and might change soon again):
I started with a symmetric layout similar to Ergodox. With the number keys 1~5 on the left side and 6~0 on the right and in a similar fashion distributed the letters.
However, I'm really used to the traditional stagger and there, the left and right hand finger assignment is distributed rather un-symmetrical. Maybe this changes at some point, but for now this layout is much easier to type!
Your perfect layout might look different... let me know in the comments below~
Revised Left Side & 3D Print Fine-Tuning
04/27/2023 at 05:20 • 0 commentsAs promised in my last post, I transferred the (for now) finalized PCB design from the right to the left side and already ordered 5 assembled boards that are in production right now!The same thing was needed in the past when transferring the initial PCB design from the left to the right. This time, it turned out less painful (TBH I would like to automate a lot of things, maybe with skidl and pcbflow as mentioned in that article: https://kbd.news/Keyboard-as-Python-code-1834.html).
At the same time, I was iterating on the 3D resin prints. Here is the case, which was an almost 100% fit. I did print it first on my FDM printer before, but the tolerances are just a bit different:
The gap between plate and case is a bit larger than I wanted it to be. The fix was easy and the new version should be spot-on!
On the picture above, the print looks a bit scratchy from the post processing, but it is not so pronounced under normal light conditions. In fact, I was surprised how great all the parts turned out.
Only on my second batch, I had a few parts with some excess material here and there, that in my opinion, comes from a faulty resin printer LCD/mask:
You can see a little blob on the middle element. I hope that was just a one-off issue.
The cirque trackpad mounts do fit. However, I have to raise them a bit higher from the plate, otherwise the finger drops too much down when reaching for the trackpad. Also, the keycap stems need some more tuning:
While I can just push the FDM print onto the MX-cross of the switch, the resin print is not so flexible and then sometimes cracks. Making the cross cutout at the bottom just a little bit bigger should fix that.
While waiting for the assembled PCB, I'm working on the software side and it is about time to do that :)
Revised Right Side: Final Version?
04/08/2023 at 14:59 • 2 commentsIf you have been following my blog posts, you know that a little mistake with my last PCB prevented me from using it as a keyboard: Pin 1 of all OLED displays was on the wrong side.
So I had to route half of the PCB again... Of course I took the chance to rectify some things I was not 100% happy with in the first iteration.
Right Side V2 Changes:
- The RP2020 and flash memory moved about 10mm away from the switching regulators as the space in between was very tight.
- The reset and boot button, as well as the debug port moved to another location as it turned out inconvenient.
- The host USB-C port got an ESD protection chip and I added a resettable 300mA polyfuse to the board to give it perfect protection in case of shorts or similar.
- The non-inverting buffers I used were actually for 5V and not 3V3 so I decided to change them with similar ones, now matching the supplied voltage (even though they worked without any issue).
- I set the current limit for the the displays and LEDs to 250mA as all displays together could potentially draw much more current (all pixel on + max brightness), not even considering all LEDs set to fullbright. Why 250mA? The USB 2.0 specification has a limit of 5V at 500mA (2.5 Watts). With both sides connected (2x250mA) and a display voltage supply of 3.7V I could reach 1.85Watts. That leaves enough room for 2 MCUs, 2 status displays, some other components and losses (also the switching regulators are not perfect). If it turns out to be too strict, I can set it to a higher value by swapping a few resistors.
- With esthetics in mind I changed the package of some components, but the IC type stayed :)
Ready? Set. Go!
I felt very confident and therefore, ordered 5 fully assembled boards with ENIG finish!
And... surprise, surprise: The boards look amazing:
Flashing the RP2040 worked and after connecting all displays without any key switches, I could see that I didn't mess up revision 2 ;) Everything is working!! No bodge wires, no software fixes to work around hardware issues!
Professional 3D Print
Almost at the same time, the SLA 3D prints, I ordered arrived and the quality is amazing! Compared to the 3D prints coming out of my FDM printer the tolerances are a bit tighter, so I had to do a bit of tuning here and there before I could put everything together. However, it worked out and I couldn't be happier:
All 3d prints (case, 1U+1.25U stems, display holder and cirque holder) are designed in OpenSCAD, so fine-tuning for the next batch will be very easy. The resin parts give it a professional look and my personal impression is that it feels more like a real product :)
TA-DA!
Okay, so now with displays and lights on:
I didn't fix the displays indices yet and with that they don't show the correct content. However, I was so happy that it all worked out and just took a quick picture. There is some homework left for me!
Now it is time to bring the same changes to the left side and the hardware of the PolyKybd Split72 is ready!!
Sidenote
You might have noticed that it is really tricky to make good photos when the displays are on because those are much brighter than the environment. At some point I should maybe do some more professional HDR shots!
(until that time, I will just tweak light and contrast of my cell phone pictures)
Thanks for reading and let me know what you think about it in the comments!
Generate A Case With KiCad And OpenSCAD
03/28/2023 at 09:36 • 0 commentsThe very first case for the left side was done manually. Just like I did for my macro pad prototype - measure everything and then model a fitting case:
Well, still I had to break away some parts as you can see :-P, this process usually needs multiple iterations to really fit well.
For left side case, I had at least some automatic step, so I haven't had to measure everything: In KiCad, I exported an SVG from the PCB outline and started modelling a case around that:
That worked, but I don't want to repeat that for the right side as it is just too much manual work. Also any changes to the position of the LEDs, USB connector or the mounting holes would be a disaster!
The good part is, that I now know how the case should look like from the design standpoint!
What I also learned, is that there would be less manual modelling needed, if I placed all bottom SMD parts well within the PCB (well at least 2mm+). Then I don't need to modify the edge where the PCB sits on because of colliding parts. Obvious? Right? Seems like I had to experience that first to realize.
Next Iteration
So for the right side I wanted to start with a more generic and automated approach that ideally creates a fitting case based on the PCB alone.
To make the project as open as possible, I resisted to use any modelling software that would need a paid license. With these two ideas in mind I was wondering if I could use OpenSCAD to programmatically generate the case.
I already used OpenSCAD for the keycap stems and the display holder, why not for the case as well?
So How does it work now?
I still export the outline as SVG, however without all the cut-outs for key switches. In KiCad, you can select which layer to export and each layer can be a different SVG. So the most convenient thing is, to copy the board outline to a separate layer (since the key switch cutouts are also on that layer, but we don't need them). Then create a layer for each of the other physical features like:
1. Usb port cut-out (just a rectangle that can be extruded and subtracted)
2. LED cut-out for the status lights (just a line starting from the middle of the part perpendicular to the board outline)
3. Reset and Boot-Select switch cut-outs (again just rectangles)
4. And finally the stand-offs, which I just redraw as circles in a new layer as circles with the exact diameter of the drill hole.
So all together that makes 5 different SVGs (well, I also optionally had cut-outs for debug ports but that will not matter in the end).
All Set?
Unfortunately, my outline was not perfect (tiny gaps) and I had to fix it with InkScape to make one polygon out of it (I don't remember the exact steps, maybe there is some expert who can comment? Maybe there is a command line tool to do that?).
Apart from that, for some reason, all lines in my exported SVGs where in groups and I just got all lines out of any groups and deleted the empty groups as OpenSCAD had issues with objects in groups.
After these little cosmetic operations, I can load the generated SVGs into OpenSCAD:
With the offset command I can make the extra space around the PCB for the case. All that missing is a linear_extrude and we already three dimensional representation:
If the outline or another physical property ever changes, I just regenerate the SVGs and run OpenSCAD again. That's all! I love that!
You can find the current version as usual on my git repo: https://github.com/thpoll83/PolyKeyboard/blob/master/case/right_side.scad
And as usual my apologies for the mess in the repo, I really need to cleanup the structure. It's just like my desk ;)
Remaining Manual Work
There are a few things that might need manual adjustment once a while, but it's really manageable:
- The logo as I just placed it loosely in the middle
- The wedge shape in the front
- The mount points for tenting (on the side)
3D Printing
Of course I 3D printed the case and it turned out well:
I would like to show you with the new PCB, but the updated right version is currently in production and will take a few more days...
