Update. It was the caps!
A project log for MicroRF Remote
4 axis Remote for Arduino. 4/5 ch/servo RX.
saulSaul 04/19/2023 at 10:450 Comments
Replaced the advil caps with a couple electrolytic capacitors of the correct value...
It Works!
Will figure out a basic case and add Trim adjustments for the joysticks.
3/4 axis are off by +3...
Having multiple remotes should really speed up my other projects.
Now I can have more customized code on both rx/tx.
