Nothing special, just a log of my progress on a DLP printer build. Should be usefull to others in the UK looking for sources etc.
preload.stlThe carriage with a place to mount roller bearings to preload the IGUS linear slide. 3D print this.Standard Tesselated Geometry - 159.75 kB - 01/20/2017 at 23:15 |
PrinterAllDXF.dxfAll The DXF files for cutting, all from 6mm wood stock, other than the roughly A4 sheet with 4 holes. That should be transparent dark red acrylic.AutoCAD DXF - 502.77 kB - 01/20/2017 at 23:13 |
Just a quick picture of the printer with projector mounted. Just a few connections to be made to the RPi for the end stops etc. Interestingly, (by design) the projector does not need to be modified for this build area, so this slightly larger design could be seen as 'easier' than the 'LittleRP' design where the focal distance needs to be reduced to allow it to focus on the small build plate.
Today we cut and assembled the MDF structure of the machine. There are a few errata to note (that I will update in the files at some point). The holes for the projector are not exactly right, we manually drilled them 6mm to the left (projectors point of view). Also the small front pannel below the door needed to be 6mm higher. (Please ignore this rubbish reporting, this is mainly notes to self ;) )
Hello, I will update this post over the weekend with any interesting notes.
The DXF files for cutting are attached to this project.
