Do-It-Yourself KIT available
A project log for Isetta TTL computer
TTL Retro computer runs 6502 and Z80 code. Has video, sound and filesystem. Runs a Windows-like OS. No microprocessor or FPGA.
roelhroelh • 05/21/2025 at 17:45•0 Comments
KIT Available
The first Isetta kit was successfully built by Vadim (see picture):
And the second kit was built by Hans-Jürgen in Germany.
In [this log] you can see all ins and outs of the kit. Of course, with the kit, you will receive the latest schematics and software versions. [ edit: You can order your kit at the new Envionic website. ]
On the first pcb, a few modifications had to be done (the wires that you see on the pictures). But there is now a new pcb design where these modifications are not needed.
SymbOS
Good progress was made on the SymbOS implementation. The most serious bugs are fixed now. Currently I am working on the microcode for a sound generator, that will work similar to the AY-3-8910, and that can also be controlled by SymbOS.
