Death of a wasabi
A project log for Dummy battery for an EOS RP
You could buy one but some of us are dummies
lion mclionheadlion mclionhead 04/01/2023 at 01:550 Comments
The lion kingdom's wasabi battery puffed after 3 years, creating a source of dummy battery parts.
There's no way to open it without destroying the plastic.  Once inside, we're greeted with 2 uninsulated cells which are very easy to short circuit.
The jackpot is the gold plated circuit board.  It would cost a fortune to make that.
The object of the game is to connect B+ & P-.  BC is a balancing terminal which doesn't exist in a dummy battery.  B- isn't connected to the terminal.
The enclosure has tabs for aligning the board.
