Just a small update.
All parts for the XY conversion arrived and I'm currently working on the technical drawings for the Aluminum parts.
The images don't show the final arrangement. The linear blocks are raised with 3D printed spacers and the ballscrew is mounted below the aluminum plate.
It uses 500mm HGR20 rails for the Y axis. The aluminum parts are 15mm thick.
gedm-dev
