Finally more cuts made by others coming in
A project log for G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
gedm-devgedm-dev 05/31/2025 at 23:310 Comments
Thanks to Nikolay for the great work. He went through the journey to understand how everything works and was able to cut a puzzle piece out of 8mm steel. after just a few days try and error.
The cut was done with 0.8A on the PicoEDM with the G-EDM electronics.
Fresh out fo the water:
