Four axis ESP32 Motion controller PCB
A project log for G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
gedm-devgedm-dev 05/14/2023 at 04:330 Comments
The ESP32 and the motionboards are now compacted onto one single 4 layer PCB.
The board provides an output for a 12v fan and some dip switches to set the microsteps for XY and the spindle.
Only the z-axis uses software controlled microstep settings. XY and the spindle use fixed microstepping.
This should make the wiring a lot easier.
