X axis is running
A project log for G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
gedm-devgedm-dev 05/19/2023 at 18:040 Comments
The X axis is finally running. The small Nema-17 Motor has enough power to drive the axis at all microstep settings. Pulleys and belt are printed.
The ballscrew came without a nuthousing so I printed one. It is bigger and uses 4x pressed in M6 nuts to mount the table.
