Flipper At Home
Me: "Mum, can we buy a flipper?"
Mum: "We have a flipper at home!"
NFCWhenever I see the flipper zero, I think to myself "ah that would be so cool to have, but I probably won't use it and have feature mentioned as a module somewhere.
So I wondered how I would do the discount version of a "Flipper Zero" and found this ST7735S display and ESP32-C3
DIsclaimer: this is basically a joke and will never be as cool and thought threw as the flipper zero, don't buy things and expect solutions from me! Just because the hardware is there, doesn't mean there's software to support it.
Display and Joystick board + ESP32
https://www.aliexpress.com/item/1005004539320086.html
Display board:
https://github.com/MoonFox2006/Air101-LCD
flipper zeroFlipperAtHome
usb-cyesyes
Display128x64 monochrome160x80 full color
SD Card slotyesyes
infrared transceiveryesmaybe
CC1101 sub 1GHzyesachievable
125kHz RFIDyesnobody needs that
oh wait maybe star wars fans
NFCyesPN532 can emulate tags
(probably keyfeature for most)
Bluetoothyesyes
WiFiNO NO NO NOyes, nice
1-Wireyeshm never tried that
MCUSTM32WB55RGESP32-C3
buzzeryeseasy
Vibration Motoryessure why not
badUSByesoh god maybe with the version that's not serial
  • programming menu and hardware options
    davedarko04/28/2023 at 09:03 0 comments
    For 2-3 evenings I was working on "perfecting" the look of the menu on the small display, until I realised that the flipper zero has four menu styles (that I know of) https://chaos.social/@davedarko/110255372561304158 . I got to a point where I was very pleased, having a "128x64" pixel area in orange, centered in a slightly brighter orange 160x80 area, which is the display size.
    The other day I saw the LilyGO T-embed price reduced to 28€ with shipping, I had my eye on it for a while and decided to buy it as a second candidate. Keep in mind that it usually goes for 42€ instead. The external dimensions are almost the same and I can use the 320 x 170 as a 160 x 85 display by just doubling up the pixels.
  • first order arrived
    davedarko04/18/2023 at 19:31 0 comments
    Today I received two ESP32-C3 boards, one with native USB CDC controller connected to the USB plug and one with a CH343 connected, plus two LCD boards, because why not, they were cheap! (I also got that fish console from prev post, why did I buy that??)
    I'm a bit irritated on why there are two versions, why would you want a board with an extra serial converter? To be able to use the GPIO pins 18 and 19, which are the USB pins for the integrated CDC? Well let's see what and how many pins I need then.
    I found this pinout diagram and expanded it, so it shows what pins are the LEDs connected to.
    Here are the boards again:
  • looking for a case or at least inspiration
    davedarko04/08/2023 at 17:26 2 comments
    While browsing through "handheld console" I found this weird "plug into tv" consoles and it definitely has the "XYZ at home" vibe.
    https://www.aliexpress.com/item/1005002426662072.html
View all 3 project logs
thunderlord123 wrote 5 days ago point
By change how did you actually get the firmware to play nice with the hardware
davedarko wrote 4 days ago point
I didn't, I "just" wrote arduino code that draws the menu in the same way :) it's in no way compatible
[deleted]
davedarko wrote 05/09/2023 at 18:37 point
Hey Bryce,
thank you for the input - I'm currently heavily involved with hackspace stuff, so projects fall a bit short and this was a bit of an ironic "shit post" first. I do like to have some sort of small multitool though and had a good time to explore how to design a menu for the display - this will definitely be worked on, but on a slow pace.
have a nice one and thanks again
zyndram wrote 04/12/2023 at 06:15 point
add wifi mesh or audiomodem, tnc etc.
davedarko wrote 04/12/2023 at 11:40 point
is that a request? :D sounds like a whole different usecase but also a software thing that should work on any esp32 board?
zyndram wrote 04/12/2023 at 17:13 point
yes ;-)
for example https://github.com/nakhonthai/ESP32IGate or https://github.com/amedes/ESP32TNC  https://github.com/arms22/SoftModem  https://github.com/romanz/amodem etc.
Simple sound modem with two jack + baofeng or other radio and can send mesh messages. Any radio could be turned into a network device.
Hayden Kroepfl wrote 04/11/2023 at 01:49 point
I was taking a look into this a little earlier too, the main thing I was seeing that wasn't available hardware wise was the switchable band pass filtering on the CC1101 modules. The ones on ebay/ali are all set at one frequency (normally 433, but some are the 903 or such). The flippers analog front-end has a 3 way switchable filter set for each of the bands that the module can support, I think anything properly comparable would need to do something similar with the modules unless you're fine with only a single band.
Would be nice to find or build some module that uses the CC1101 but has a switchable analog front end, possibly into switchable antennas better tuned for each band, or like the flipper does with different end loadings of the antenna depending on the band.
davedarko wrote 04/11/2023 at 05:31 point
it's not gonna be the strongest signal, but it would still work with the one antenna setup. There's a CC1110 in the girltech im-me messenger and you can use it as a crude spectrometer for example. For an "at home" version I could live with a 433MHz module for using it in Germany.
zyndram wrote 04/12/2023 at 17:08 point
or 868MHz strongest signal and a lot of empty space/time
Dan Maloney wrote 04/10/2023 at 21:09 point
I saw a short on YT today where a guy uses a Flipper to tweak the smart meter on the side of his house. At least the meter was smart...
Seeing as Amazon is now no longer selling Flipper Zeros, building your own might be the only way to get one pretty soon.
davedarko wrote 04/10/2023 at 22:40 point
I saw it in their shop recently, but I felt conscious about my money for once and thought 200 Euros would be too much for a device that might end up in the drawer anyways :D
There was a guy at Hackaday Berlin using it as a slide clicker, that was nice to see too! But I have so many modules flying around anyways, I should really build something with those.
