The Cardboard Computer - IO is my name
Back to overview
My goal is a 4-bit CPU using recycled cardboard substrate and Diode Transistor Logic. This is an educational platform for me.
Wayne Verish wrote 07/18/2017 at 19:06 point
love lt!
Check out my cardboard computer on myYouTube channel gort59
Dr. Cockroach wrote 07/18/2017 at 21:39 point
Your Minivac601 is great :-) I wanted to do a relay computer but ended up with a large stock of transistors so went that route :-) These projects keep us both out of trouble Lol
SHAOS wrote 12/21/2016 at 17:56 point
I really needed something like that when I was young :) how difficult to solder components to those caps? Do you use regular solder and flux? Any special tricks?
Dr. Cockroach wrote 12/22/2016 at 01:04 point
Hello Shaos, nothing special, just 60/40 rosin core. the fasteners take the solder very well. Just have to heat sink the transistor and diode leads while soldering.
SHAOS wrote 12/25/2016 at 06:18 point
Great! I've decided to do something very similar, but with "Goldtone Thumb Tacks" - see here https://hackaday.io/project/10724-germanium-calculus
Dr. Cockroach wrote 12/25/2016 at 09:03 point
I love your calculator project idea :-)   I have used silver and gold tone and the gold took the solder a bit better. Thank you for the link.
SHAOS wrote 12/25/2016 at 22:46 point
Thanks!
coletonn wrote 12/21/2016 at 14:16 point
Wow, ok. So it's just a larger Cardboard NAND gate. I just like how it's cardboard, makes everything better.
Dr. Cockroach wrote 12/22/2016 at 01:11 point
Good evening coletonn, not sure if better but sure is cheaper. Looks strange but then so am I for trying this project. Have learned from a lot of web sites so not inventing anything new but it is all new for me.
Dr. Cockroach wrote 12/25/2016 at 22:51 point
I should start calling my cardboard cutouts VLC's or very large chips :-)
