Still on hold but not for long
A project log for The Cardboard Computer - IO is my name
My goal is a 4-bit CPU using recycled cardboard substrate and Diode Transistor Logic. This is an educational platform for me.
dr-cockroachDr. Cockroach 07/19/2018 at 23:450 Comments
Here it is July 19, 2018 and IO is still on hold as I continue to work with other projects for this years HaD contest. I have decided that I wired myself into several corners on IO and once work resumes, I will revise some of the sections and make other improvements as I come across problem areas.
Thanks for all those who are followers and there will be more of IO and later, IO2
