September 19, 2017 - A crude 7 segment display
A project log for The Cardboard Computer - IO is my name
My goal is a 4-bit CPU using recycled cardboard substrate and Diode Transistor Logic. This is an educational platform for me.
dr-cockroachDr. Cockroach 09/18/2017 at 23:503 Comments
Well, I got sidetracked today. I read a post about 7 segment displays and decided to try something out for IO. Please don't laugh but I think that this will fit right in for IO's front panel.
Here is the unpowered 7 segment display using my Christmas leds.
Number 0
Number 1
Number 2
Number 3
Number 4
Number 5
Number 6
Number 7
Number 8
Number 9
Hex A
Hex b
Hex C
Hex d
Hex E
Hex F
EricH wrote 09/24/2017 at 04:06 point
Works surprisingly well with two per segment!
Martian wrote 09/22/2017 at 20:49 point
Looks good to me, I was going to do something similar a while back with 7 white LEDs.  I was going to use a 'frosted' plastic or material on top of the LEDS, to defuse the light.  Then on top of that apply stencil cut out on black plasticard of a (large) standard 7-seg display.  The end effect should look quite good.
Dr. Cockroach wrote 09/22/2017 at 23:59 point
I might add some kind of diffuser later on once I see how well the finished circuit works. It would look better with something :-)
