Code and Construction has begun!
A project log for Toner/Laser 3D Printer
3D printer using a laser to melt the material on a semi stationary bed with minimal components.
thundersqueakThunderSqueak 07/31/2014 at 00:560 Comments
I spent the weekend working on the code to control the servo mechanism, when it gets closer to completion I will post it.  I have been contemplating on using a thin sheet metal for the mirror mount hardware instead of the Lexan I had originally considered.  The reasoning for this is ease of cutting without cracking.  I have also picked up a heat-sink that will be suitable for the laser mirror mount.  This needs to be drilled at an angle and a set screw made so that the laser can be mounted in properly.
