Adafruit Feather Logger
We started using an Adafruit Feather Adalogger to use and test our code before getting the parts that are running late.
Temporary Arduino Dimensions
Arduino dimensions for the practice one while we wait for ours to come.
Arduino Guide
https://web.cecs.pdx.edu/~gerry/class/feather_sense/on-board/blinkNeoPixel/
We used this link to help us set up the Arduino ID. Used it as a guide.
Dial and Base Plate
Here is a screenshot of a CAD of both the dial and baseplate of the watch together. This is how they will fit. Will hold the encoder and battery.
Week 2 summary: This week on our project, the two parts of the CAD were put together, displaying what we hope the final product of the top part of the watch will look like. The Ada fruit feather adalogger was also set up to start the coding process. The code will be tested on the Ada fruit feather adalogger as we wait for the parts of the watch to arrive, to ensure the code works, and to find any errors before transferring it to the actual pieces of the watch.
