CODE :
//Define LED RGB
int rougePin = 9;
int vertPin = 10;
int bleuPin = 11;
//Define light sensor
int capteurLumiere = A0;
//variable initialisationto stock the value reading by the light sensor
int valeurLumiere = 0;
#include "Servo.h"
Servo servo; // creation of the object "servo"
void setup() {
pinMode(rougePin, OUTPUT);
pinMode(vertPin, OUTPUT);
pinMode(bleuPin, OUTPUT);
Serial.begin(9600);
servo.attach(12); // attache le servo au pin spécifié
void loop() {
//to read the value of the light sensor
valeurLumiere = analogRead(capteurLumiere);
//to show the value lof the light in the "moniteur série"
Serial.print("Valeur de lumière : ");
Serial.println(valeurLumiere);
//if the value of the light is lower than 500, then turn on the LED RGB
if (valeurLumiere < 500) {
digitalWrite(rougePin, HIGH);
delay(500);
digitalWrite(rougePin, LOW);
digitalWrite(vertPin, HIGH);
delay(500);
digitalWrite(vertPin, LOW);
digitalWrite(bleuPin, HIGH);
delay(500);
digitalWrite(bleuPin, LOW);
servo.write(90); // demande au servo de se déplacer à cette position
//if the value of the light is greater than or equal to 500, then turn off the LED RGB
else {
servo.write(0);
