PCB prototypes ordered. Will start software development after those are in hand. Circuits are optimized for minimal footprint and cost, not ideal signal handling or impedance, so some tweaking might be needed to get the RP2040 starting up reliably. Some users report needing PICO_XOSC_STARTUP_DELAY_MULTIPLIER = 64 on custom boards.
Upload Gerber, Pick and Place, and Bill of Materials files to your PCB assembler of choice
2
Add shim to part of PCB that inserts into USB-A port
Only default PCB thickness (e.g. 1.6 mm at JLCPCB) is likely to be cost effective, so the part of the board inserted into the USB-A port will need a shim to fit securely; the material used should be nonconductive
can You put fuzix on this? meybe rom or similar data?
