mysoltrk - a solar tracker, reinvented
A different approach for a solar tracker, alternative movements, to be installed on the outside, to optimize the efficiency of solar panels
We want to create a new, different version of solar tracker, to increase the performance of solar panels.
Our challenge is create a new device:
- small, suitable for balcony or small gardens
- solid, it must stand outdoors with any weather
- solid, with three support points instead of one
- 3D printed, sufficiently waterproof
- minimal hardware, low cost
- self-tracker device, without GPS or WIFI
We want to install this device outside the windows, balconies, small gardens where there is little space and we want the chance to charge smartphones, power banks or external cameras taking up less space and higher energy production
During lockdown, we've started to study how to build a little solar tracker to charge powerbanks, smartphones or run small fans.
Existing projects use servos (for little solar panels) or linear actuators.
We've found some limitations in projects that use linear actuators:
  • big/heavy infrastructure to support solar panels
  • they often make use of external batteries to carry out the movements
Here our new approach:
  • the solar panel gain three support points, we think will be more sturdily and wind resistant
  • the panel can be moved to hook sun during the day where the sun gives off more energy
The two-more support point are realized with actuators, they can be placed both on the base or hooked to the pole that supports the panel (like the example).
There are some challenges we want to address:
  • build cheap actuators
  • build new actuators with a kind of waterproof
  • build a low power board that not use any kind of battery (use only energy from panel)
  • do it all on a low budget
  • write a software from scratch to implement new algorithm for movements
Logs published in date order:
  1. A little linear actuator
  2. The construction - part one
  3. The construction - testing movements
  4. The construction - part two
  5. The construction - designing the brain of mysoltrk
  6. Software design: transform an idea into real movements
  7. Ready to go outside: the assembling
  8. Let's go outside to find the sun - first test
  9. Software design: work in progress
  10. In search of the sun: software test in the field
  11. From prototype #2 to #3: here is the PCB board
  12. Prototype #3: PCB completed
  13. The final report
  14. No news .. good news!
  15. Winter is over..
Adobe Portable Document Format - 235.29 kB - 09/27/2023 at 09:06
Preview
Download
Mysoltrk Gerber.zip
Gerber for mysoltrk
x-zip-compressed - 33.39 kB - 09/01/2023 at 10:05
Download
mysoltrk-viewfinder.stl
Viewfinder for mysoltrk project
Standard Tesselated Geometry - 4.58 MB - 05/15/2023 at 20:00
Download
mysoltrk-joints.stl
Joints for mysoltrk project
Standard Tesselated Geometry - 3.01 MB - 05/02/2023 at 13:14
Download
mysoltrk-actuator.stl
Complete actuator build for mysoltrk project
Standard Tesselated Geometry - 7.69 MB - 04/20/2023 at 12:55
Download
  • 2 × N20 M3*55 Gear Motor 6V DC Motors for actuator
  • 2 × M3 bolt for actuator assemble
  • 2 × M4 nut and bolt. You can try with M3 but maybe need to use some glue for actuator assemble
  • 2 × M5 nut for actuator assemble
  • 1 × plywood base for stand
View all 18 components
  • Winter is over..
    Fulvio04/05/2024 at 15:25 0 comments
    Hi everyone,
    It's early spring and the prototype is still outside chasing the sun!
    The bad weather ruined the plywood a bit but the circuit and the engines withstood the rain and cold.
    From a mechanical point of view we had to:
    - replace a damaged nut (inside the actuator)
    - replace the collar that supports the panels
    during the winter, when the sun was available, we were able to charge a power bank, which is proving to be a convenience!
  • No news .. good news!
    Fulvio10/30/2023 at 11:00 0 comments
    Hi, mysoltrk is completed, but it doesn't mean that we are not continuing to work on the project.
    We are preparing for winter, so as to test the hardware even in adverse weather.
    In the country where we live now it is autumn, and these days the rain is abundant:
    In this (wet) photo you can see another prototype, built around three panels 6W 5V monocrystalline panels put in series to provide 15 volts.
    We verified that after a heavy rain, the panel turned toward the sun on its own, a sign that the circuit is working and well protected.
    The other thing we noticed is that the angle of the panel is lower than a month ago, a sign that the viewfinder and photoresistors are correctly following the sun and doing their job properly
  • The final report
    Fulvio09/29/2023 at 14:39 0 comments
    Hello everyone!!!
    Finally we can share the latest tests with the new solar panels.
    Thanks to the PCB board, we are able to quickly build the mysoltrk devices.
    The outdoor tests focused on the strength of the actuators and reasonable weight/size of the panels to be used.
    In addition, the tests showed that the design can be put outdoors without worrying about weathering.
    Here our video published for the contest. We hope you like it.
  • Prototype #3: PCB completed
    Fulvio09/15/2023 at 08:05 0 comments
    Hi everyone, we have completed the assembly of the PCB:
    WARNING:
    To avoid burning out the circuit, set step-down output to 5.0-5.2V before to mount to PCB !
    (and secure the screw with a bit of glue)
    For this purpose, please use an external power supply as the input, with a voltage value similar to the solar panel being used.
    We also prepared a box, the whole thing looks professional to us :)
    We are busy to build two working prototypes, with two types of solar panels.
    We will update you in the coming days.
  • From prototype #2 to #3: here is the PCB board
    Fulvio09/01/2023 at 10:08 0 comments
    Hi everyone!
    We have completed the development of PCB board, here the result:
    You will find Gerber as usual in "Files" section.
    We will show you the result as soon as we get it home.
  • In search of the sun: software test in the field
    Fulvio08/21/2023 at 19:53 0 comments
    Finally we are ready to present the development result of the last month:
    But, before continuing, we want to thank the jury for choosing our project.
    This is further motivating us. Thank you!
    We have complete the first round of tests, with encouraging results.
    You can find the source code here:  https://github.com/fulvioalessio/mysoltrk-solar-tracker/tree/main/SolarTrackerReinvented
    Let's look at some snippet of code:
    void loop()
        unsigned long startedAt = millis();
        workIsCompleted = false;
        readPhotoresistorValuesAndEvaluateMovements();
        Serial.println("Tracker start");
        while (!workIsCompleted && !isLowVREF())
            movePanel();
            if (millis() - startedAt > MAX_MILLISECONDS_WORK)
                Serial.println("Exceeded work time limit");
                workIsCompleted = true;
            else
            delay(10);
        Serial.println("Tracker complete");
        processMosfet();
        sleepForMilliseconds(SLEEP_DELAY);
    The loop() code follow the flow chart that we had shown in the previous log.
    Summing up:
    1. read photoresistors values and calculate movements
    2. move panel
    3. read photoresistors values (again) and calculate next movements
    4. if there are no moves or time is up, go to sleep; otherwise return to step 2
    5. after completing the movements, evaluate whether to turn on the mosfet based on the amount of light read
    6. sleep for a set amount of time
    7. repeat from step 1
    Quite simple isn't it? Well, the hard work is to create a right combination between the reading of the photoresistors, the reading of the pin shunt and of VREF. And a lot of trying..
    But how are the movements performed? Here is an example:
        if (moveUp)
            Serial.println("move UP ^^");
            eos_br = false;
            if (!move(ACTUATOR_R_PIN1, MAX_MILLISECONDS_MOVEMENT, MAX_SHUNT_VALUE_R))
                eos_tr = true;
            eos_bl = false;
            if (!move(ACTUATOR_L_PIN1, MAX_MILLISECONDS_MOVEMENT, MAX_SHUNT_VALUE_L))
                eos_tl = true;
    To implement the upward movement, the two actuators are switched on one at a time. This way you get the desired result without consuming too much.
    Variable "eos_tr" (Top Right), "eos_tl" (Top Left) are used to mark the limit switches. This is useful for movements calculation.
    However, the code has been written for maximum readability and understanding.
    Let's watch together the video made with a DYI esp32cam powered directly by the mysoltrk prototype:
    Sorry for the low quality video. esp32cam provides low resolution images with little detail.
    However we think it is enough to show how it works
    Project completed ? That's all ? Well.. no!
    Thanks to the award received, we now have the opportunity to extend the challenges we set ourselves at the beginning.
    Our plans include the purchase of material useful for the construction of further prototypes
    We want to explore these further aspects:
    • What size of panels can we move with our actuators ?
    • Is there a possibility to use the same technique to move large panels?
    They seem like demanding challenges to us, but given the results we have achieved, we are quite optimistic !
  • Software design: work in progress
    Fulvio08/05/2023 at 15:19 0 comments
    Hi everyone!
    We are quite busy developing solar tracking software.
    The algorithm is almost defined, we are studying some behaviors in the field (directly in the sun)
    Here is a preview of the flowchart, the "loop" function on Arduino code:
    Prototype in action:
    Stay tuned..
  • Let's go outside to find the sun - first test
    Fulvio07/03/2023 at 18:41 0 comments
    After completing the assembly, we had to wait for a sunny day.
    Here is the result of the test with prototype #2 using the code showed on this log:
    At this point we can consider the hardware is working as expected and we can concentrate on the software implementation of the solar tracker.
    Stay tuned!
  • Ready to go outside: the assembling
    Fulvio06/26/2023 at 13:02 0 comments
    These days we have focused on transforming the breadboard circuit into a solderable breadboard circuit, adding a small box to enclose everything.
    Here is the result of prototype #2:
    As you can see, all components used on prototype #1 are in prototype #2. We have added a little led for debug (bottom right) connected to the mosfet pin.
    The circuit inside the box:
    We have added two usb connector for USB IN and USB OUT, fixing with hot glue:
    By connecting the circuit to the actuators, to the photoresistors and to the solar panel we obtain this beautiful result to see:
    Now we are ready to do some tests outside.
  • Software design: transform an idea into real movements
    Fulvio06/16/2023 at 07:55 0 comments
    Now it's time to test the prototype #1 with the actuators.
    We have realized a Arduino example, you can find it at github
    Before we talk, let's watch the video:
    The first think we said was: it works!
    With a tiny processor, with a bunch of discrete components we are able to pilot a DIY actuators without limit switches.
    This trick helps us to significantly reduce the complexity of the hardware.
    Some notes about the code
    // Program params
    #define MAX_SAMPLES                 10
    #define IGNORE_SHUNT_VREF_FOR_      1000L   // milliseconds
    #define MAX_SHUNT_VALUE             20      // threshold
    #define MIN_VREF_VALUE              100     // below this value the external power supply (eg: solar panel) supplies too little energy
    #define MAX_SECONDS_MOVEMENT        180     // max seconds to move actuator
    1. MAX_SAMPLES: we use an array to read analog values and give an average of the values derived from the scan
    2. IGNORE_SHUNT_VREF_FOR_: when motor starts, we can ignore first values
    3. MAX_SHUNT_VALUE: a reference value, above this value it is assumed that the motor is straining and therefore it can be deduced that it has reached the end of its stroke
    4. MIN_VREF_VALUE: a reference values, below this value it is assumed that external power (solar panel) produce few energy and the engine should be stopped
    5. MAX_SECONDS_MOVEMENT: an arbitrary value, high enough to reach the end of actuator stroke
        digitalWrite(ACTUATOR_R_PIN1, LOW);
        digitalWrite(ACTUATOR_R_PIN2, LOW);
        digitalWrite(ACTUATOR_L_PIN1, LOW);
        digitalWrite(ACTUATOR_L_PIN2, LOW);
    When program start, we put L298n pins to low.
    Next, we put pin to high once at time to keep consumption low.
    The result is one move at time for a single actuator.
    Current absorption
    As you can see on video, the circuit consumes about 0.1W with motor off and 0.2W with one motor on.
    We think a good milestone has been reached!
View all 15 project logs
  • 1
    Buy supplies
    In "Files" section you can download a pdf file whith a bill of materials.
    Consider that you may already have some of the material listed in your garage, such as screws and plywood.
  • 2
    Buy PCB
    Download "Mysoltrk Gerber.zip" and put an order on your favorite pcb manufacturer
  • 3
    Buy Solar panel
    Buy a solar panel from you favorite online store.
    You can choose from a myriad of panels, choose one not too big e not too heavy.
    The dimension of panel for the first prototype of mysoltrk is about 17x17cm, a solar panel for ip camera.
View all 15 instructions
michal wrote 04/15/2023 at 05:37 point
What kind of sensors are you going to use to measure sun light power ? Or in other words, how are you going to decide how to move the solar panel to get max power ?
Fulvio wrote 04/15/2023 at 08:46 point
Hi Michal, my approach is to use simple hardware. For this prototype I'll plan to use photoresistors
Dan Maloney wrote 04/14/2023 at 21:18 point
Cool idea. Looks like the wider the panel, the longer the range will be for horizontal tracking. Looking forward to details.
