Rewriting the firmware
A project log for Portable Sound Visualization AR Device
A portable AR device that superimposes an image showing the location of a sound source on an image captured by a camera.
airpocketAIRPOCKET 05/12/2023 at 13:220 Comments
It's Friday night, so I'll make some progress. I wanted to write the latest version of the firmware, but since I'm using a new PC, the USB serial communication device driver was not installed. Since MaixBit uses CH552, I need to install the driver on my PC following the instructions on this page.
https://wiki.sipeed.com/soft/maixpy/en/get_started/install_driver/bit.html
The method for rewriting the firmware is explained on this page.
https://wiki.sipeed.com/soft/maixpy/en/get_started/upgrade_maixpy_firmware.html
Also, while it is not directly related to this project, following the tutorial will allow you to easily try face detection using yolo with edge processing.
https://github.com/knorth55/maixbit_tutorials
If you have not experienced a demonstration of Edge AI using microcontrollers before, this is a great opportunity to try it out. I highly recommend giving it a go.
