Assembling_You_WizFi_Trundlebot.pdfBuild instructions document when using the WIZnet - WizFi360-EVB-Pico.Adobe Portable Document Format - 2.66 MB - 04/19/2023 at 15:02 |
Trundlebot_Trundlepad0.stlThe "Trudlepad" for the front of the Trundlebot. 3D print one of these.Standard Tesselated Geometry - 1.13 MB - 04/19/2023 at 15:02 |
Trundlebot_PCB_Layout.pdfA diagram of the PCB layout.Adobe Portable Document Format - 94.68 kB - 04/19/2023 at 15:02 |
Trundlebot_Motor_Holder0.stlThe housing for the motos. 3D print two of these.Standard Tesselated Geometry - 214.93 kB - 04/19/2023 at 15:02 |
Trundlebot.kicad_pcbThe KiCAD file for having your own circuit board manufactured.kicad_pcb - 156.62 kB - 04/19/2023 at 15:02 |
Trundlebot_Bowerbank_Holder.stlA holder for a power bank. Optional if you don't want to have the Trundlebot tethered by a USB cable. 3D print one of these.Standard Tesselated Geometry - 233.48 kB - 04/19/2023 at 15:02 |
Trundlebot_Chassis.dxfThe main chasses of the Trundlebot. Laser cut one if these of you can. Make one out of anything if you can not. Thick cardboard will work.AutoCAD DXF - 33.36 kB - 04/19/2023 at 15:02 |
Trundlebot IO Mapping.pdfWhat pin is connected to what port for the more advanced programmer.Adobe Portable Document Format - 24.20 kB - 04/19/2023 at 15:02 |
Trundlebot_Schematic.pdfA schematic of the circuit board.Adobe Portable Document Format - 114.02 kB - 04/19/2023 at 15:02 |
Trundlebot PCB Layout.pdfThe component layout of the PCB.Adobe Portable Document Format - 94.68 kB - 04/19/2023 at 15:02 |
Trundlebot_bom.csvThe bill of materials for online manufacturing.Comma-Separated Values - 3.06 kB - 04/19/2023 at 15:02 |
