Catch hive high up in hawthorn tree
A project log for Ai Honey Bee Swarm Detector / Predictor System
Local C02 sensor and weather data scraped off interwebs predict swarming
capt-flatus-oflahertyCapt. Flatus O'Flaherty ☠ 05/19/2023 at 14:320 Comments
If you look carefully inside the red disc near the entry hole there is a scout bee, probably from another hive starting to go into swarm mode. However, one single bee is not likely to affect the inside CO2 levels very much!
