Clean energy: Energy Conversion
Wave energy: Boats on waves can be a source of clean energy.
Public Chat
The force which is comes from Boat's pitch motion, is very suitable for water pumping. By placing a swing weight on the boat it is possible to get that force. Yes, we can pump water by using the forces from boat’s pitch motion caused by the wave energy. This is the easiest technique to harness energy from ocean (/ river) waves. This nonstop pump can provide sufficient water for irrigation and for hydro power-station. There is also no problem for the conversion of big and or small size of waves. That is, smaller waves will pump less water and larger waves will pump more water. For details https://doi.org/10.14738/aivp.113.14613
Golden values Blue force which is comes from Boat's pitch motion, is suitable to water pumping. By placing a swing weight on the boat it is possible to get that force. A graphical presentation of the motion of the swing weight, at four different positions of the boat in the pitch movement are as shows in figures 2 to 5.
JPEG Image - 894.25 kB - 12/04/2024 at 19:02
Preview
140423 my new paper.pdf
New Paper :> Wave energy: Boats on waves can be a source of clean energy.
Adobe Portable Document Format - 855.22 kB - 04/19/2023 at 18:53
Preview
  • 1 × Waves [Ocean/ River]
  • 1 × Boat/ Ship By waves playing with contained swing weight and pump.
  • 1 × Swing weight & Pump Piston Mechanism [installed inside the ships] By waves pitch motion, swing weight operates the pump with boat/ ship.
  • 1 × Anchor Mechanism
  • 1 × Pipes [as required] Flexible plastic pipe
View all 7 components
View project log
  • 1
    Equipment s, materials and building
    Very easy
View all instructions
Md. Moniruzzaman wrote 12/02/2024 at 18:21 • point
https://drive.google.com/file/d/10tks74J_2kRxhloYwN-pNWiZfdRdikAt/view?usp=drive_link
Md. Moniruzzaman wrote 04/19/2023 at 20:40 • point
Easy technology based solution, any engineering firm can implement this
