Eagle Bug #2
A project log for Cadsoft Eagle Professional Use
Useful hint and information about creating schematics and layouts with Eagle
andre-moehlAndre Moehl 01/11/2017 at 10:451 Comment
If you want to Mirror your hole board, be aware that inner Layer are not changed. This can run into wrong layout. In my case I found this bug when I made a panel of one layout.
K.C. Lee wrote 01/11/2017 at 14:16 point
Sounds like their mirroring is only intended to flip the footprint and corresponding breakout and traces for a part between top/bottom side.
