main.rarThis file is the Alexa example of Espressif, using the ESP-ADF libraries, used on Lyra T starter kit. Just compile to Lyra T, no changes from the original.https://github.com/espressif/esp-adf Here some discussion about portuguese port https://github.com/espressif/esp-va-sdk/issues/65 RAR Archive - 4.92 kB - 04/21/2023 at 13:23 |
hackaday.pyThis is the Lambda Python example que invoke the Amazon Text Rekognizer service.Who call this event ? The AWS IoT when receive a JPG image from ESP32 WEBCAM :) Works together with AWS IoT core ACT RULES https://www.youtube.com/watch?v=IkR2g0fJ94o x-python - 3.68 kB - 04/21/2023 at 13:22 |
hackaday.jsThis is the Lambda Javascript example that talks with Amazon Alexa and make communication with AWS IoT, where the ESP32 WEBCAM is connected.Who call this event ? The AWS IoT when receive a JPG image from ESP32 WEBCAM :) javascript - 8.93 kB - 04/21/2023 at 13:21 |
SCH_hackday.schdoc_2023-04-10.jsonThis this the first Schematic version of Shield to the Arduino ATMEGA.Newer version will be draw in the robot Chassis. It´s on EasyEda format. easyeda.com JavaScript Object Notation (JSON) - 66.89 kB - 04/21/2023 at 13:20 |
hackaday.pcbdocThis is the first PCB version of Shield to the Arduino ATMEGA.Newer version will be draw in the robot Chassis. It´s on EasyEda format. easyeda.com pcbdoc - 780.81 kB - 04/21/2023 at 13:19 |
hackaday_converter.stlThis is the 3D STL converter from step motor axis to wheels hole.Standard Tesselated Geometry - 22.54 kB - 04/21/2023 at 13:19 |
hackday_step_support.stl3D Support to the step motor to fix on chassisStandard Tesselated Geometry - 286.80 kB - 04/21/2023 at 13:17 |
robot.inoFirst version of ARDUINO MEGA robot controller.ino - 7.11 kB - 04/21/2023 at 13:16 |
robot_chassis.inoVersion of ARDUINO MEGA robot controller, now with 8 infrared sensors.ino - 20.33 kB - 04/21/2023 at 13:15 |
Robot_Webcam.inoVersion of ESP32 WEBCAM, acessing AMAZON, taking picture to rekognizer images and receive Alexa commands and finally sensding using infrared to Arduino mega.ino - 20.13 kB - 04/21/2023 at 13:14 |
