About the Game
Dungeons of Daggorath was a very popular first-person RPG in the early 1980s. It was compatible with the Tandy TRS-80 Color Computer 1/2/3.
It was a very early three-dimensional game that allowed the player to explore a dungeons and battle monsters via a text based interface. That interface is used to move around, fight, pick up or use items, and much more. However, the vast majority of the time, the commands entered revolve around moving and attacking.
For these common actions, the text-based interface can be a bit slow and clunky, so I modified the source code to enable the right joystick (I always wished this was possible as a child). Moving the joystick moves the player around the dungeon, just as would be expected. The button triggers the command ATTACK RIGHT.
Being a first-person game, I could not resist the temptation to insert a few Doom characters in place of some of the originals. The CoCo may not be able to play Doom, but it kinda-sorta can do something like it.
I also gave the player unlimited power and health, which is great for exploring and testing, but that boost can be left out for those that want the challenge.
After assembly, the binary can be burned to a ROM chip mapped into the cartridge port, or should also work with any decent emulator. I assembled the source code with LWASM.
Speaking of source code, the former CEO of DynaMicro, Inc. very graciously released the source code for public distribution, but only in its original form. Since I have modified it, I cannot distribute my work. However, one can still recreate Dungeons of Doom without too much trouble by:
- Downloading the original 6809 source code.
- Making the modifications I have listed below.
- Assembling the code.
Media
Screencaps of modified enemies:
For comparison:
Playing on my CoCo 2:
Modifications to the Original Source Code
- In
CD.ASM:
After line 623, insert the following:
TEMP1 RMB 1 ; NAB BAGP RMB 2 ; NAB
- In
HUMAN.ASM:
Replace line 13 with:
LBNE PLAY20 ; yes ; NAB: BNE to LBNE
On line 17, insert the follwing code after the PLAY10 label:
; NAB - check for joystick input.
; Joystick button. LDA 65280 ANDA #1 CMPA #0 BNE NOBUTTONPRESS ; Attack right. LDU #PRHAND JSR ATTACKRIGHT JMP NOMOVE
NOBUTTONPRESS
JSR [$A00A] ; BASIC joystick reading routine.
LDA $015B ; Right joystick y-axis CMPA #10 BHI NOMOVEFORWARD
; Move forward JSR PMOVEFORWARD JMP NOMOVE
NOMOVEFORWARD CMPA #50 BLO NOMOVEBACKWARD
; Move backward JSR PMOVEBACKWARD JMP NOMOVE
NOMOVEBACKWARD LDA $015A ; Right joystick x-axis CMPA #10 BHI NOMOVELEFT
; Move left LDB PDIR JSR PMOVELEFT JMP NOMOVE
NOMOVELEFT CMPA #50 BLO NOMOVE
; Move right LDB PDIR JSR PMOVERIGHT
NOMOVE ; NAB - END check for joystick input.
Replace line 47 with:
LBRA PLAY10 ;loop ; NAB - BRA to LBRA
- In
HUPDAT.ASM:
This is optional, if you want infinte health. After line 40, add:
CLRA ; NAB - IDDQD CLRB STD PDAM
- In
ONCE.ASM:
After line 284, add:
CLR TEMP1
This is optional, if you want infinite power. After line 288, add:
LDA #$7F ; NAB - Max power. STA PPOW
- In
PATTK.ASM:
After line 11, add this label:
ATTACKRIGHT
- In
PTURN.ASM:
After line 20, add the label:
PMOVELEFT
After line 29, add the label:
PMOVERIGHT
After line 153, add the label:
PMOVEFORWARD
After line 166, add the label:
PMOVEBACKWARD
- In
SOUNDS.ASM:
On line 16, insert the following after the SOUNDI label:
; NAB - sound back on (reading joystick turns it off) STA TEMP1 LDA $FF23 ORA #8 STA $FF23 LDA TEMP1
Replace line 198 with:
SNRAT1 LBSR SNOISE ;get a random noise value ; NAB - L
Replace line 279 with:
SNWSH2 LBSR SNZNVA ;get some noise ; NAB - L
Replace line 285 with:
SNWSH1 LBSR SNENVN ;decompression subroutine ; NAB - L
On line 309, after the SNOUT label, insert:
On line 320, insert after the SNOISE label:
Replace lines 411-412 with:
LBLS SNCLK4 ; ; NAB - L LBRA SNOUT ; ; NAB - L
- In
D3.ASM:
Replace the spider vector list with:
; Body
SPIDER SVORG 40,100 SVECT 40,105 SVECT 42,115 SVECT 52,125 SVECT 60,128 SVECT 68,125 SVECT 78,115 SVECT 80,105 SVECT 80,95 SVECT 78,90 SVECT 68,80 SVECT 60,77 SVECT 52,80 SVECT 42,90 SVECT 40,100 SVNEW
; Eye SVORG 50,101 SVECT 52,106 SVECT 56,106 SVECT 58,101 SVECT 56,96 SVECT 52,96 SVECT 50,101 SVNEW
; Pupil SVORG 53,99 SVECT 53,103 SVECT 55,103 SVECT 55,99 SVECT 53,99 SVNEW
; Mouth SVORG 64,90 SVECT 64,95 SVECT 64,101 SVECT 64,105 SVECT 64,112 SVECT 69,114 SVECT 73,110 SVECT 74,101 SVECT 73,92 SVECT 69,88 SVECT 64,90 SVNEW
; Teeth SVORG 65,95 SVECT 70,97 SVECT 65,99 SVNEW SVORG 65,103 SVECT 70,105 SVECT 65,107 SVNEW SVORG 71,99 SVECT 66,101 SVECT 71,103 SVNEW
; Horns SVORG 44,118 SVECT 40,124 SVECT 35,127 SVECT 45,127 SVECT 50,123 SVNEW
SVORG 44,87 SVECT 40,81 SVECT 35,78 SVECT 45,78 SVECT 50,82 SVNEW
SVORG 40,108 SVECT 35,111 SVECT 41,114 SVNEW
SVORG 40,97 SVECT 35,94 SVECT 41,91 SVEND
; End of Spider vector list
- In
D4.ASM:
Replace the viper vector list with:
VIPER
; Head SVORG 55,120 SVECT 55,130 SVECT 55,140 SVECT 62,147 SVECT 69,140 SVECT 75,140 SVECT 83,140 SVECT 83,130 SVECT 83,120 SVECT 75,120 SVECT 69,120 SVECT 62,113 SVECT 55,120 SVNEW
; Eyes SVORG 62,118 SVECT 66,124 SVECT 66,129 SVECT 62,123 SVECT 62,118 SVNEW
SVORG 62,142 SVECT 66,136 SVECT 66,131 SVECT 62,137 SVECT 62,142 SVNEW
; Mouth SVORG 70,122 SVECT 70,130 SVECT 70,138 SVECT 78,138 SVECT 78,130 SVECT 78,122 SVECT 70,122 SVNEW
SVORG 70,124 SVECT 72,124 SVECT 72,130 SVECT 72,136 SVECT 70,136 SVNEW
SVORG 78,124 SVECT 76,124 SVECT 76,130 SVECT 76,136 SVECT 78,136 SVNEW
; R SVORG 68,140 SVECT 73,145 SVECT 78,150 SVECT 85,152 SVECT 88,153 SVECT 98,155 SVECT 98,150 SVECT 88,145 SVECT 88,140 SVECT 98,139 SVECT 108,138 SVECT 118,136 SVECT 124,135 SVNEW
; L SVORG 68,120 SVECT 73,115 SVECT 78,110 SVECT 85,108 SVECT 88,107 SVECT 98,105 SVECT 98,110 SVECT 88,115 SVECT 88,120 SVECT 98,121 SVECT 108,122 SVECT 118,124 SVECT 124,125 SVNEW
; Legs SVORG 120,128 SVECT 114,129 SVECT 104,129 SVECT 94,128 SVECT 94,131 SVECT 104,132 SVECT 114,132 SVECT 120,133 SVNEW
; Horns SVORG 74,146 SVECT 68,148 SVECT 77,149 SVNEW
SVORG 74,114 SVECT 68,112 SVECT 77,111
SVEND
About the Author
Nick Bild
