• 1
    Unpack your Kit
    Your kit should include:
    1 - Unassembled box
    1 - Pre-stripped red wire
    3 - Pre-stripped blue wires
    1 - Battery holder
    1 - CR2032 battery
    2 - 499 ohm resistors
    2 - Self adhesive magnets
    1 - Adhesive dot
    1 - Red 3mm self blinking LED
    1 - Green 3mm self blinking LED
    1 - Blue 3mm self blinking LED
  • 2
    Glue left & back panels to base
    Place your box base on a flat surface. The base can go in any orientation you prefer. Take the left panel making sure that the engraved side is facing out and the hole is towards the back. Place glue along the indented side of the base and the left panel. Line up and hold until secured. Place glue along the indented sides of the back panel. Place panel with engraving side facing inward.
  • 3
    Place lid in holes & glue right panel
    Place the tab on the lid through the hole on the left panel. Apply glue to right panel and line up, making sure the engraving is facing outward and the hole is towards the back. Place the other tab on the lid through the right panel. Let the lid rest on the base while the right panel dries.
