Added the SR Latch to the main board
A project log for Magnetic Core Memory The Dr Cockroach Way
My not so fancy example of Magnetic Core Memory using fairly cheap cores and free parts from my junk box.
dr-cockroachDr. Cockroach 04/28/2023 at 18:440 Comments
April 29, 2023 -  Cleaning up some of the clip leads and moved the SR Latch to the main glass board. Now three days without any bit flip errors.
The SR Latch is now located at the lower right with the black reset switch to the right of the red Led. The toggle switch selects between Write and Read and the red push button switch left of the toggle sends current to the selected core via the clip leads. The clear white Led at the far right indicates a flip of the selected core.
