Coaxial Hotend [gd0144]
Full-colour FDM? Continuous fiber? Low resistance 3D printed circuits? Tube extrusion for light parts?
This is a hotend for my CR600S (a modified CR-10) that aims to allow me to bulk-buy 4 filament colours but print in 4096. Any feature implemented afterwards is a bonus.
I'm mainly doing this because I currently don't have a working printer, and quite a few of my designs (such as #Teti [gd0022]) are dual colour prints. Conviniently, I bought loads of white filament, and it would be great to just buy 3 more spools to get any specific hue I want, such as the elusive milky green (#b7c1b0).
I want to allow for feature expansion should I need it, but FDM 3D printing in general is looking like it's plateaued when I've got the #SecSavr Suspense [gd0105] to bring into reality, so I'd rather just focus on the main aim to finish what I started over 5 years ago (I bought a diamond hotend for my CR10 and never installed it).
  • [P] All other components
    kelvinA2 days ago 0 comments
    The main ones are the internal grooving tools and the 20mm grub screws that make the insert, but the heatsinks, 4mm grub screws and cleaning filament have all arived.
    I've now gone to my uni's engineering department and the technitian that was looking over my design said that it was going to be a long process and will probably take till next Friday at the earliest (keeping in mind that the UK has a bank holiday next Monday). The long processing time is mainly because there are so many positional and tool changes required. I may be an engineering student, but I don't study mechanical engineering, so the fact that the design is complex but creatable (given the right tools and skill) is a win in my book.
    These tools are actually suprisingly small.
  • [P] 6028 Fans
    kelvinA6 days ago 0 comments
    Seems the fans were the only thing not in the AliExpress combined delivery and also the first to arrive. Royal Mail was notified of this parcel on the 16th May and the combined delivery 21st May (yesterday), so it could be another week+ before I get the components I need.
  • [M] Carriage Mount
    kelvinA7 days ago 0 comments
    I think... that's actually everything I need now for a complete hotend solution. Took just over an hour to plan and model, but wayyyy simpler than what I had to do for the #Revolving Hotend [gd0012].
  • [M] Cooling ducts
    kelvinA05/13/2023 at 14:35 0 comments
    I've now modelled the cooling ducts. The airways themselves are not optimised at all, but it should serve as a good starting point.
    I also did this to see if there was anything else I might need before I bought the AliExpress BOM, since I've found it unrecommendable to buy components before the assembly file has been completely modelled.
    I'm planning to self-tap M5 screws into the 6028 fans. Here's what it looks like with the fans inside:
    Hopefully, the plastic being 3mm away from the hotend is good enough for it to not melt.
  • [T] Threads and feedback
    kelvinA05/12/2023 at 17:59 0 comments
    So, learning that PCBWay isn't going to notice a possible manufacturing issue until they actually try to manufactor it, I was more involved this time. For starters, if I self tap the 3D printed holes, the print is only $39.80. Considering that it seems that the minimum cost is around $37 for any part via this service, and it was the price nozzleboss paid for theirs, I think this is a win that this is under $40.
    Dimensions: 31.26*20.8*34.5mm
    However, I had also recently watched the below video about SLM printing, and overhangs are essentially required for 90 degree overhangs.
    So I asked if the internal channels were printable, and my service rep Eleven indeed confirmed that there's a risk of blockage since support has to be there.
    Now, just like how Apple sent off 2 teams to either start from the iPod or iMac to get to the iPhone, it seems I'm now trying to get a solution from both 3D printing and lathe machining. While the 3D printed version has a 5th filament input already integrated and doesn't have to worry about the 16 leak-plugging grub screws, I'd imagine that more schools / unis would have a metal lathe than a metal 3D printer (though I'd like to change that).
    So the technician agreed that it's a bit tough to start a hole off-center to a cylindrical face. It does seem possible to create enough of a 32mm across-flat hex from a 35mm solid rod to cover the off-center positions.
    The next is that an M3 tap looks like this:
    As you might be able to notice, the full width threads start maybe halfway down, yet the threads in the design are as short as 3mm need to go almost all the way to the end of the hole (the DIN914 cone grub screws thread doesn't go thoughtout the entire length).
    I haven't found an official tool, but the tech is just planning to trim down the M3 thread. I forgot to ask what happens about the M6 threads though. Even if I got the thing printed, I'd still have to think about this issue.
    Were going to try and make it in aluminium.
    Oh right, speaking of that 5th filament input, it may be possible to do for the CNC edition by drilling a 4mm hole 4mm deep into a copper/brass and titanium heatbreak and then putting a 4mm OD x 2mm ID tube inside.
    I would like to know how these kinds of throats are made in the first place and how the 2 materials are secured together.
  • [M][R] Preperation for Uni round 2
    kelvinA05/08/2023 at 11:14 0 comments
    Now that I'm armed with the knowledge PCBway has directly and indirectly given me, I thought I'd try to see if the university technitians could attempt to manufacture.
    For the stock material, there's only really round bar on ebay (the place I've been finding the material stock in previous logs charges £9 for delivery). 35mm and 40mm sizes are suitable.
    35mm should provide threads that are just-about long enough to work. A 40mm round bar can be reduced to the 33mm hex in the traditional design.
    Next, now that the bore is 5mm, I have access to this internal grooving tool that has a rounded edge:
    This should help with keeping a consistent internal pressure.
    The only issue is that the max reach of the tool is 10mm and the middle internal groves are 10.6mm. Thus, I need to reduce the channels to 1mm and the height/spacing of the internal grooves to 1.2mm.
  • [E1][M] Asking PCBWay for a brass insert
    kelvinA05/05/2023 at 21:00 0 comments
    [May 5, 21:00]
    Honestly, I don't know why I didn't even entertain the idea of even asking them to create this insert for me and instead searched high and low on AliExpress.
    I took the slot values from this grub screw diagram:
    Then again, looking at the one below, perhaps the values I need are 1.2 and 1.8mm?
    Oh and while were on the subject, I'm switching to these grub screws:
    Unlike hex, I think these should be virtually unstrippable. I do NOT want a grub stuck inside down the line if I need to remove it.
    I think it's nice having grub screw consistency too, and this would mean that everything is made in brass.
    [May 7, 07:00]
    Seperate part? Seperate fee.
    - PCBWay Service Team (paraphrased)
     Figured that's how it worked.
    3D printing won't save me here either, with a price just under $38. It totally seems that there's a $35 engineering setup and handling fee wrapped up in the price. I'm not sure if the autoquoter works correctly with assemblies, because it gave the same price as the heatblock-only file.
    In related news, I was sent the same outdated verification files twice. On the second time, I got this message:
    Once again, our factory can produce the files in the attachment.
    If you can accept it, there will be no additional charges.
    If it is not acceptable, please cancel the order.
    Thank you for your understanding.
     With the starter "once again", it can only mean that my sales rep is not referring to the updated files sent on the 5th May, but the older ones attached. The filesizes were slightly different too, so it's not like ther's some email client mistake either. There's also been so many changes since my initial 27 April quote that it's probably best to start afresh with a brand new quote.
  • [E1][M] Metal 3D print edition
    kelvinA05/05/2023 at 14:09 0 comments
    [May 5, 15:20]
    So I was still thinking about how nozzleboss got thier solution printed for 37$ whilst my traditional manufacturing solution is 70$ with another £10 ($12.50) in off-the-shelf parts for the internal geometry. Like all the "I just got access to a metal 3D printer" engineers before me, I wanted to see what complexity reduction a 3D print editon would be.
    Firstly, I sent over the latest Lathe Edition file to PCBWay:
    It's an expensive part, so I thought I'd at least add the finishing features found on my brass supervolcano, such as the 0.5mm chamfer on otherwise sharp edges and the fillet around the thermistor wire cutout:
    Then I did a Save As and started doing the tweaks I needed to do. Looking at PCBWay's minimum wall thickness table, I went with making sure walls were over 1.2mm thick.
    Those flowy internal channels look nice
    I can even add an angle to help the flow:
    This is the point I got to when I realised that I didn't have to conform to a circle or hexagon but could have whatever shape conformed to where I needed it (so obviously I got a filleted chamfer in here).
    This allows for a 5-in-1-out solution without additional manufacturing complexities.
    I like how easy it was to go from lathe -> 3d print design. I'd imagine it'll be an uphill effort going the other way around. The technical drawing is also simplified to just pointing to threads:
    The PCBWay autoquoter says $46 for aluminium, which is 75% of my first 3d print autoquote. Hopefully, since this doesn't have as many tapped threads as the first design I had, it actually stays close to this and doesn't double in cost. Additionally, the time spent searching AliExpress for components could've been reduced too, so I can see the benefits of 3D printing.
    Because it's aluminium, the mass is a rather light 42g. Sounds like a significant weight saving, but the lathe edition is 45g when cut from aluminium.
    [16:20] Looking at the block, and the fact that the heatsinks extend a bit over the edge, I thought I could actually turn the + looking shape into a smooth rectangle, and it was a success:
    In terms of mass... it's 45g. In terms of heat conductivity... the cartridges are further away from where all the molten plastic is. In terms of price... it's more expensive:
    So it's like an all round net negative. Might as well make the thickness 24mm so that the thermistor has more thread length and the block flush with the heatsinks:
    At least it looks nice and compact:
    And I guess with this design, you can actually have dual thermistors since they're so close to the heatsource.
    [May 6, 08:40] The quoted price for the non-slim edition is $72.
  • [E2][R] PCBWay still can't manufacture?
    kelvinA05/03/2023 at 09:38 0 comments
    [07:00] I wake up and I get this:
    From PCBWay:
    Sorry, our factory does not have a suitable cutting tool for
    processing your parts. You have two options:
        1. If the internal groove is not useful, we suggest you remove
           it.
        2. Increase the size of the hole to 5mm or more, and your
           internal groove will also increase accordingly.
     Me: A solution... is being processed. (plays electro/cyber background music)
    Obvioulsy, both 0mm internal groove and 5mm outer bore is a nogo and the solution will fail. However comma (Swoozie reference),  I probably should've checked AliExpress first and not the wider internet when looking to see if a micromachining grooving part existed:
    My university CNC technitians also probably don't know of AliExpress' existance, though I could understand that expensive 5-axis machines usually are paired with expensive tool bits (they said some are £200).
    At least with this, it's more applicable for a maker with a metal lathe in this day and age to create this part. I can only imagine that the F dimension is a square, since the bore dimension isn't dimensioned the same way as the other lengths, though I can imagine if B is supposed to be the dimension parallel to L1.
    0.6^2 * pi = 1.131mm^2
    1.4 * 1.4  = 1.96mm^2
     So, even with a 0.7mm groove, I should still have a pressure drop from the 1.2mm internal channel if CSA is anything to go by.
    If they can only approach to the top of the part, L1 = 15 will be needed:
    However, I can't see why it's not possible to go into the tapped hole. There, for a 1.4mm tall groove, the distance is only 6.2mm:
    The length of this would be 24mm. The groove diameter stays at 4.5mm for a 0.7mm internal cut.
    It also turns out MGR tools are standard and not something niche:
    I've also found something that confirms my estimate about dimension B:
    And then I found this:
    Looking at the rightmost view... I'm starting to see why... PCBWay asked for a 5mm center hole, or at least larger than 3mm. Not sure why 5 though. I'd imagine 4mm would've worked though.
    Okay... so looks like that insert / tube is non-optional.
    Also unfortunately, for M3 bolts, these inserts have an M5 outer thread instead of M6:
    WAIT! THERE'S HOPE! LOOK:
    Not all that sure how you'd tighten it. I assume the bolt turns in the same direction, so tightening it also tightens the outer thread. Then, I don't know how you'd get the thread out again other than using pliers.
    Muhahaha it comes in brass!
    AND with a slot so that unscrewing is possible! Sugoi. Unfortunately, the mental simulation predicts leaks using this method, creeping up through the small gap between the M3 bolt and threads.
    There's also these things, but I don't know how I'd tighten them:
    Again, not sure how to tighten. Cut your own, perhaps?
    Drats! This is just what I need, but M6->M3!
    There are these in stainless:
    Now, if I have to use a 5mm bore, I'm not solutionless:
    I could pair this inner thread positioning pin along with the above conversion screw. This is what the 12mm long version would look like:
    I also wonder if the below solution would be acceptable:
    It uses a 3mm hole at the top, allowing the tool to come in from the bottom ideally. 3mm Od x 1 - 2mm ID also exists, as well as 3mm throats, so it might be possible to actually DIY a custom throat for a solution.
    [15:30] (playing different background music
    I've considered long brass inserts:
    I've also found flat versions of the stainless steel pin things:
    It turns out that the CSA between a 4mm and 5mm circle is >7mm^2. At the same time, since the internal grooves act more like cookie cutters than a traditional wall, perhaps this is not as important. I could always ask PCBWay if I can get a 4.5mm groove by reducing the depth to 0.7mm. That runs the risk of everything having to be a precision fit though,...
  • [E1][M] Starting on the cover
    kelvinA05/02/2023 at 18:55 0 comments
    Before working on the mounting solution, I thought it would be a tad better to model what I want the hotend assembly to look like at the end of the day.
    It would've been nicely compact actually if it wasn't for my medling cooling requirements. Over the years, I've found (dual) 40mm blowers (both 10 and 20mm thick) to be inadequate for cooling (fast 0.6mm track width) prints. 5015 is so large in diameter that it's usually more benificial to go straight on up to 6028 blower fans which boast 3 - 4x more airflow.
    In this design, one blower is for part cooling, and the other is to thoroughly cool the heatsinks (the airflow does a U turn).
    I'm just slightly worried that this design will collide with something on the X axis. I remember that I ran into something when I tried the cover for the Revolving Hotend.
    [23:20]
    Other than "because I have space", part of the reason why I'm using a 6028 for cold-end cooling is because unused filament paths will conduct heat upwards, facilitating a clog. I also don't want to deal with watercooling so I might as well try something with more oompf than a 30mm or 40mm radial fan. Additionally, I'm planning not to use the auto-fan feature, so that I can turn off the fan during printing. Why would I want to do this? To allow heat to conduct higher up the throat and hopefully soften the filament that would've otherwise been stuck in place.
    It might be necessary to use the #SecSavr Select [gd0091] as an automatic input blocker, where 4 inputs have CMYK and the other 4 are stainless steel wires (or something that doesn't conduct heat well, but also doesn't melt and/or degrade at normal printing temperatures). Ideally, there'd be a firmware timer that automatically blocked the input if it hasn't been used for a specified amount of time, with the target balance being long enough that the materials aren't constantly switching out, but short enough to mitigate clogs. This point and the paragraph above were learnt from reading old deckingman posts about his research into mixing hotend printing.
View all 17 project logs
