I bought two PenPads online for a total of about £15. The first one self-destructed after I let some NiMH rechargeables run out inside it (be warned!) but the second one is working fine, after I replaced a capacitor which had died causing the screen contrast to go haywire. Naturally, I've had to give the casing a good scrub with some isopropanol-based hand sanitiser! (For those who don't know - the PenPads had a lovely soft-touch rubber coating when new, leading to a horrid sticky-touch goo coating 30 years on...)
Using a piece of DOS software, and an RS232-to-USB converter, I can transfer data to and from the PenPad's address book. But it's 2023 - who says I should stick to addresses? Each address book entry can hold about 250 characters - more than enough for news headlines, tweets, train times and weather forecasts - or even a portion of a book (did somebody say 'Kindle replacement')?
Anyone who has owned an unrestored Amstrad PenPad in the last ten years or so will be aware of The Goo Problem. Essentially, Amstrad applied a lovely soft-touch rubber coating to the PenPads when they were manufactured in 1993ish. Like all rubbery coatings, the PDA600's soft-touch sheen degrades over time, meaning that by the time Ashens reviewed one (hilariously) for his YouTube channel in 2012, the coating had degenerated into a horrible sticky goo. All PenPads will succumb to this eventually, unless they're on the Moon, but I've phoned NASA and apparently that's quite unlikely ;-)
Luckily, the coating is fairly easy to remove - at least, to a degree that makes the PenPad vaguely touchable again. I used some isopropanol-rich hand sanitiser for this, and while my treated PenPad looks a bit 'distressed' as a result (see pictures) it's actually done a really good job of getting the gunk off.
If you want to try and de-gloop your PenPad, I have a few tips:
- start gently, using a minimal amount of sanitiser. This is especially important on the front casing if you don't want to rub off the logos.
- remove the front casing altogether to reduce the risk of getting sanitiser into the electronics. You can do this by removing the screws on the back, opening the flap, and then *very* gently pull the flap upwards whilst holding the main body of the PenPad on the table. The cover should lift off easily - be warned that the digitiser might flop out of place as you do this, because the cover anchors it in place.
- don't scrub the casing with a green kitchen scourer as this'll leave scratches (I learnt the hard way...)
This method seems to leave the inner part of the flap with little 'pimples' on it - I'm assuming these are little bits of rubber that the sanitiser wasn't strong enough to remove. It's not a perfect fix; no such thing exists - sadly, you will never be able to make your PenPad look truly 'original' again.
