It works!
09/06/2023 at 18:59 • 0 commentsAnd it works, finally!
All finished and ready:
Sitting on a pile of OpAmps:
And first sound test with some headphones i would not worry about:
And oh yes this works as intended!
Nearly working
09/03/2023 at 09:30 • 0 commentsAbout 80% finished: The ZIF socket does not fit into DIP socket holes, it needs larger holes, so i soldered it "on top" like a SMD part... Further it seems i forgot to order some parts, so its back to order more parts... -
PCB´s arrived
06/20/2023 at 16:08 • 0 commentsthey are here! And they look good 😊
now its assembly time, next Log will be with the soldering iron
pcb parcel lost
06/04/2023 at 14:38 • 0 commentsThats a first for me, the package is lost :-(
It is now getting manufactured again but it will be to late to complete this project in time for the Op Amp Challenge deadline.
So meanwhile this is how the SMD and alternative THT footprints are used:
Only R4 shows on the silkscreen, the _1 variant is hidden.
It is a 1206 SMD Footprint in R4 and a THT Axial 1/8W D1,6mm L3,6mm with 7,62mm spacing as R4_1 combined.
It is possible to mix SMD and THT so you can use up whatever is on hand
Classic 47, a DIY kit for single Op Amp´s
05/22/2023 at 18:54 • 0 commentsSearch online for "Classic 47 Headphone" and you will find kit´s to solder that are basically cmoy headphone amplifiers.
As im still waiting for the PCB´s i soldered up such a kit to give it a go:
Both Op Amp´s are already in sockets and its delivered with a set of NE5532.
So far i have given it a quick test to confirm it works, and then tried to hear a difference against OPA604 and AD8065. But i cannot say that its a clear difference...
ZIF and dual or single
05/13/2023 at 19:45 • 0 commentsWhile waiting for the PCB let´s use KiCad´s 3D view to show how the ZIF socket will look when mounted:
The ZIF socket is stacked in the DIL socket´s, i placed some resistors too close so on this version of the PCB its not possible to solder the ZIF socket directly... This will be fixed once i have build up the first amp and therefore discovered the other hidden bugs still inside...
It´s possible to use Dual or Single Op Amp´s, but dont use both at the same time, or maybe give that a try?
A 28 pin ZIF socket is used, that gives 1 row spacing between the Single and Dual Op Amp´s.(the ZIF is not needed, inserting the Op Amp´s directly into the DIL sockets is ok. but it will not look as fancy...)
Bag of Parts arrived!
05/08/2023 at 10:07 • 0 commentsThe Parts arrived, this is a bag full of Op-Amp´s and everything else needed for the build up.
The red item in the lower left corner is a DIL ZIF socket, with above some SOIC ZIF sockets. Like this its possible to test different OP Amp´s without soldering them in, or lets say thats the plan :-)
Now im waiting for the PCB´s to be shipped...
