Started a while ago and kinda forgot about it. I used games as much as I could for CS assignments, would probably have been good for round one....
The screen has a micro sd slot on spi, with wifi should mean enough storage space for multiple games with a basic ui launcher.
Gameboy layout looks nice but fitting buttons and a joystick in that space...
Might just split the controls from the screen completely.
decided a tiny pcb would help finish starting.
11 pins with 5v/3v3 in. gnd and 8 control pins for reset, backlight dimming, address select and sd card.
