I've got the project installed in a stairway at a friend. We had to adjust the sensors a bit the first time after i made some adjustments on the sensor mounting side. I soldered a riggid cable on the ground base so i can bend it like i wanted too.
It's all still working after a few weeks and its a lot of fun to chase the LED's, but watch your step or else you wil catch them with your face :)
PMT
