Installed
A project log for LED Stairway
The stairway has been upgraded with some LEDs on every step and are triggered to run up or down when you want to use the stairs.
pmtPMT 01/29/2015 at 10:430 Comments
I've got the project installed in a stairway at a friend. We had to adjust the sensors a bit the first time after i made some adjustments on the sensor mounting side. I soldered a riggid cable on the ground base so i can bend it like i wanted too.
It's all still working after a few weeks and its a lot of fun to chase the LED's, but watch your step or else you wil catch them with your face :)
