Green Universal Syringe
All function syringe (for disabled and able) people that reduce packaging and material cost.
Public Chat
One of the main challenges of using Syringe for handicap person who can only use one arm is first you need to open two packages of the syringe and the fluid medication and then adjust the needle, second you need to pump the fluid medication in to the syringe using the syringe pump and finally inject yourself. This usually takes to hand to perform and it is not easy to perform using one hand. There has been some efforts to solve this problem but all the syringe designs are not cost wise for mass production because the target customers are not considerable when compared to all other able bodies aimed syringe. But what if we change that by making the entire syringe the same by supplying all function syringe (for disabled and abled) people to use by storing the fluid medication in to the syringe without making the syringe larger than the current which decreases the packaging need for both the syringe and the fluid medication.
In this new syringe there will not be any need of needle protective cover saving plastic packaging, less plastic consumption because the spring uses less plastic material than the standard rigid pump, no need of fluid medication storage material and packaging because the syringe can contain maximum amount of drug sold in one bottle of packaging, cost feasible for mass production.
Therefore the main advantages of this syringe design are
1. No need of needle protective cover saving plastics consumption.
2. Avoid needle sharing because if drugs are sold with the syringe, there will not be any reason of end users to share needle.
3. No need of packaging material for drug because one packaging which contain the syringe with the drug is enough.
4. Suitable for one hand use for disabled.
View all 4 project logs
