Prototype v1 Test : Fail
A project log for PaintPal: The Quick Part Painter
Automated mini paint booth that does the painting for you!
brettbuildsBrettBuilds 12/27/2016 at 15:420 Comments
Leaks at both the hose and shrader valve. I thought I could get away with the sloppy silicon glue seals but the container won't hold pressure. I am going to be upgrading today and replacing the shrader air valve with a 1/4" compressor male coupler and using barbed to thread connectors for the tube. Add a couple nuts and rubber washers and it should make a nice seal.
