V3.0 Enclosed Sprayer Test 1
A project log for PaintPal: The Quick Part Painter
Automated mini paint booth that does the painting for you!
brettbuildsBrettBuilds 01/04/2017 at 02:000 Comments
I built a quick looking enclosure for the sprayer out of a plastic storage bin that I had laying around so now I can start to test with paints, and not have it make a huge mess. I ran a test today with the following:
Setup:
Sprayer Setup4 nozzles approx. 1.5" apart
Orifice SizeN/A
Pressure~30 PSI
PaintCheap Walmart Red Acrylic 1:1 paint/water
Total Run Time10 - 15 sec
Fluid Used2-3 oz
Test SubjectGood ole toilet paper roll
Avg Distance Between7-8 inches
Results:
Surprisingly much better than expected. Nozzles had a pretty good misting spray; however pretty wide angle so quite a bit of wasted paint. Also the paint was a bit spotty meaning it wasn't atomizing enough, so maybe smaller orifice, more pressure. Could have eliminated 2 of the sprayers. Need the ability to cut of the fluid rather and just the air. I do have a valve on the fluid line but I can access it from outside the container.
Go Forward To do:
