DIY WallBox
Easy electric recharge at home
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
As an owner of an electric vehicle, I needed a charging station at home. So here is my realization based on a commercial communicating module, µC and 3d printing panel. But I always want more! I integrated an esp32, a capacitive key and an oled screen in order to visualize the IP status, the electrical status of the sector as well as the consumption level. All this via MQTT with a nice dashboard under NodeRed. The currently functional (and very useful) project is in its phase 1. Phase 2 will consist in : - adding an RS485 communication with a DIN module (SDM120) to measure the consumption at each recharge - replace the big load selector on the front panel by a variable resistor (X9C103S) controlled by the esp32 to adapt the load according to the total consumption of the house. More details about the realization and the code will come soon.
