Putting the parts together
A project log for Chaotic Lighthouse
A circuit sculpture to participate in the 2023 op amp challenge.
mabe42MaBe42 05/27/2023 at 15:430 Comments
This was again a job where two hands are not enough, I chose to build a structure out of 10 diodes (1N4004 are more stable than 1N4148) to form the interface between the round base and the pentagonal tower.
I mounted the diodes with glue tack on a circle on paper, soldered the tower to them and then put it onto the base.
