6. Programming
A project log for Plant Foliage Health Monitor
Spectrophotometer To Determine Normalized Difference Vegetation Index (NDVI) Built With Raspberry Pi And NIR Spectral Sensor
guillermo-perez-guillenGuillermo Perez Guillen 05/30/2023 at 05:380 Comments
The libraries don't have code examples for the AS7263 sensor. According to the instructions, you have to use the AS7262 sensor as a reference and make the code by analogy: https://github.com/HeyLlama/as726x-python
Below I show you the configuration of the AS7263 sensor: The sensor gain is 16 according to the datasheet.
as7263 = AS7263()
as7263.set_gain(16)
as7263.set_integration_time(17.857)
as7263.set_measurement_mode(2)
as7263.set_illumination_led(1)
The configuration of the GPIO pins 16 (red) and 18 (green) of the rgb LED is as follows:
redPin = 16   #Set to appropriate GPIO
greenPin = 18 #Should be set in the
def blink(pin):
    GPIO.setmode(GPIO.BOARD)
    GPIO.setup(pin, GPIO.OUT)
    GPIO.output(pin, GPIO.HIGH)
def turnOff(pin):
    GPIO.output(pin, GPIO.LOW)
def redOn():
    blink(redPin)
def redOff():
    turnOff(redPin)
def greenOn():
    blink(greenPin)
def greenOff():
    turnOff(greenPin)
The R, S, T, U, V and W values are not indexed. So I got them as shown below:
        values = as7263.get_calibrated_values()
        R, S, T, U, V, W = [(value) for value in values]
        print("R = " + "{:4.6f}".format(R))
        print("S = " + "{:4.6f}".format(S))
        print("T = " + "{:4.6f}".format(T))
        print("U = " + "{:4.6f}".format(U))
        print("V = " + "{:4.6f}".format(V))
        print("W = " + "{:4.6f}".format(W))
The part of the code that calculates NDVI, and saves the data in the NDVI.csv file is the following:
        NDVI=((V-S)/(V+S))
        print("NDVI = {:4.2f}".format(NDVI))
        file = open("NDVI.csv","a")
        file.write("{0:0.1f},{1:0.1f},{2:0.1f},{3:0.1f},{4:0.1f},{5:0.1f},{6:0.1f}".format(R, S, T, U, V, W, NDVI)+"\n")
        file.close()
Finally, the next statement does the following: 1) if the NDVI value is between 0.2 and 0.65, the green led turns ON and prints the message "HEALTHY"; and 2) any other NDVI value, the red led turns ON and prints the "UNHEALTHY" message.
        if NDVI > 0.2 and NDVI < 0.65:
            print("HEALTHY" + "\n")
            greenOn()
            redOff()
        else:
            print("UNHEALTHY" + "\n")
            redOn()
            greenOff()
Below I show you the code, and then I give you useful comments.
plantfoliagehealth.py
from as7263 import AS7263
import time
import RPi.GPIO as GPIO
as7263 = AS7263()
as7263.set_gain(16)
def blink(pin):
def turnOff(pin):
def redOn():
    blink(redPin)
def redOff():
    turnOff(redPin)
def greenOn():
    blink(greenPin)
def greenOff():
    turnOff(greenPin)
try:
    while True:
        NDVI=((V-S)/(V+S))
        file.close()
            print("HEALTY" + "\n")
            greenOn()
            redOff()
        else:
            redOn()
            greenOff()
        time.sleep(0.5)
except KeyboardInterrupt:
    as7263.set_measurement_mode(3)
    as7263.set_illumination_led(0)
