Temperature Histogram
A project log for Arduino Due Thermostat
Smart, wifi capable thermostat that can be remotely accessed through the internet to record data and adjust setpoints.
dpparisotdpparisot 01/06/2017 at 12:570 Comments
Currently adding a histogram of sorts to the sleep screen. My goals for this are to show upper and lower limits (heat and cool set points) with a current temp trending between the two over a time span of 6-8ish hours. Also, I will show the status of the system during this time, Blue bar will indicate AC running, red bar will indicate calling for heat.
My initial thoughts were to show the current time in this display as well, but on second thought, i am going to leave this out for now. If I decide to display time, I will add a digital clock display or revisit this idea at another time.
