First success
A project log for AFM - from ground up
The aim of this project is to make high grade all diy AFM.
100dollarhacker100dollarhacker 06/05/2023 at 19:550 Comments
Another run, this time I got much better results.
Same technique, this time didn't drop the tip and turn electrolyte process once it finished
Here we can see the tip with x250 magnification
And here with OpenFlex microscope and x1000 magnification. The tip looks quite sharp.
