Inspiration:
GaiZhongGai-Keyboard-68
CH552G programing:
CH552G_Macropad _Plus
I scan 68 keys with 9 I/O pins -1 I/O * output, 8 I/O * input. If you press more keys > 1 you need to fix the errors in your program (Python: if K2.value==False and K8.value==True:)This system is not good for gaming keyboard.
Test ws2812b mini (3535) with PIC12F1822 32MHz internal
Now I use RP2040 (PI PICO) + CircuitPython +Thonny ( IDE )
Components:
Switch 10pcs
LEDs WS2812-3535
Raspberry Pi Pico Board RP2040
Diode or diode 1n5819
Keycap or keycap
TopCover
