ledCube PCB setup & test
A project log for S-ROV : Underwater Drone
yj-kimYJ Kim 01/02/2017 at 07:210 Comments
I just received PCB parts, and made the ledCube module. It has 2 pcb stacked sturcture. Power LED(CXA1304) is attached at the top, and led driver is installed at the bottom.
The power can be applied up to +36V, and the brightness of the LED can be adjusted by PWM of 3.3V and 5V.
Soon, I will casing the ledCube module, and test it in the water.
