S-ROV ledCube casing
A project log for S-ROV : Underwater Drone
yj-kimYJ Kim 01/03/2017 at 10:390 Comments
For waterproofing ledCube pcb, I made a simple case using acrylic. The front of the case will be waterproofed with transparent epoxy and at the same time, the LED light will not be interfered. The interior is filled with thermally conductive epoxy to serve as an electronic waterproofing and heat conduction.
