S-ROV Controller v.0.0
The following items have been revised and supplemented.
- Power supply stabilization => Solve MCU reboot when ESC turns on, and implement circuit stabilization
- Adding voltage and current sensing => Excess voltage / current can be detected.
- Adding ESC programmable pins => Can change the firmware and settings of each ESC via UART.
I will test it next week :)
YJ Kim
