Testing LED Cube in water!
A project log for S-ROV : Underwater Drone
yj-kimYJ Kim 01/06/2017 at 09:480 Comments
I get transparent epoxy adhesive. And epoxy was filled in the front and inside of the LED cube.
At the back side, I insert helicoil to fasten the LED cube.
As a result of testing in water, it works well with sufficient brightness without any abnormality, and brightness has been adjusted well.
