Handheld Model Rocket Launcher with Igniter Test
Handheld model rocket launch controller which can determine if the leads are properly connected to the engine igniter, shorted, or open
This is a handheld model rocket launch controller that has a test mode option which can determine if the leads are properly connected to the engine igniter, shorted, or open.
Handheld Launch Controller - Parts List.pdf
Adobe Portable Document Format - 169.38 kB - 07/03/2023 at 18:09
Preview
Handheld Launch Controller - Label.pdf
Adobe Portable Document Format - 401.56 kB - 07/03/2023 at 18:09
Preview
Handheld Launch Controller - Drill Template.pdf
Adobe Portable Document Format - 209.43 kB - 07/03/2023 at 18:06
Preview
jlf wrote 06/17/2023 at 15:01 point
How is that type of key and switch part called? Googling "Safety key" does not yield anything related :(
Jay Riedl wrote 07/09/2023 at 22:08 point
This is a dual contact switch that emulates what Estes has used in their handheld launch controllers for over a half-century.  It consists of a custom circuit board and two AAA battery spring contacts.  To engage the switch, you insert an Estes safety key, which shorts the connection between the two contacts.  Once I get the instructions written, you will see a picture of the safety key switch assembly.  I will also include on this project page a link to the custom circuit boards required for this launch controller.
Will O'Donovan wrote 06/14/2023 at 22:44 point
I built something similar, but using a capacitor discharge when I flew rockets as a teenager. I built it into an AMT tricorder model as the case because nerd. I like both the look and the feature set of this launch controller.
