Configum-L
Probably the smallest ever fully standalone FPGA module
Had to design this for another larger project, but thought it is cool on its own as well. Has an iCE40Lite with 3520 LUTs, internal power supply for the FPGA, 4Mbit configuration memory, and even 1Mbit serial SRAM.
The whole thing fits into a standard PLCC28 socket - small enough to be worked with conveniently, yet not ridiculously small as the raw FPGA chip itself, which is a micro-scale BGA and not really user-friendly. Haven't got much else to tell yet.
Ah, yes. Had to design a programmer for it too, that takes a bit file from the PC via USB and loads it into the configuration flash, or into the FPGA's NVM. How about that? ;-)
Yann Guidon / YGDES wrote 12/28/2016 at 21:05 point
About the size : compare with  #DIPSY :-)
JL9791 wrote 12/28/2016 at 19:06 point
Cool :)
